Various...
    MrZoon
    Posts: 48 from 2003/6/1
    Hiall!
    A few questions...
    I transferred my MiamiDX keyfiles from my old machine. MiamiDx seems
    to want me to register, but when I try to upgrade, it says that the
    keyfiles I have are the latest version. However, when I try to use
    Miamiftp, etc., it complains that MiamiDx is unregistered. What gives?
    After my HD died, I now am reinstalling everything on a new 80GB
    Maxtor (yum! DOG, this drive is quiet...) How can I update boot.img to
    the latest version? ie., where do I get it from using voyager, as ftp
    doesn't work ATM...
    If I want to make shell aliases, do I just create s:shell-startup as
    on classic Amiga? I seem to remember some alternate scenario for
    MOS.. no, wait, I think I just answered this for myself... ;-)
    Does the morphzone IRC interface work? I just see "Loading..." in the
    nick list panel.
    TAFN, TIA!
    Pete
    MrZoon ~8
  • »16.10.04 - 16:14
    poundsmack
    Posts: 1346 from 2003/6/7
    awsome avatar!
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »16.10.04 - 17:33
    MrZoon
    And if that wasn't enough, I was playing around with ModeEdit and ScreenMode trying to get 1024x768 out of my Radeon 7000... and I rebooted as suggested... and my boot drive seems dead now. I get to the "Auto-boot in 0 seconds..." message and everything stops.
    not having much fun with my peg these days... anyone have any ideas what is going on?
    Pete
    [ Edited by MrZoon on 2004/10/17 7:58 ]
    MrZoon ~8
  • »17.10.04 - 09:57
  • HAK
    Posts: 227 from 2003/2/24
    Hi MrZoon,
    Hm, happened to me some weeks ago, when I reinstalled the Pegaos of a friend and copied my settings to the machine and forgot to copy the SYS:Prefs/Preset/Monitors/<monitorfilename> according to the ENVARC:CyberGraphX/<Gfxcard>Monitor file. (Therefore it was looking for a monitorfile which was not present and didn't seem to continue anymore).
    As I don't know how you changed your settings, maybe something like this happend in your situation as well.
    Best bet would be to insert a bootable MorphOS CD and check your settings in the upper mentioned directories on the harddisk (or if you can work with the hd at all).
    Bye HAK
  • »17.10.04 - 21:07
