Posts: 131 from 2004/4/16
Hi all,
for anyone having problems printing PDFs from APDF in color, this could be your solution - at least it works perfect for me and a couple of other guys:
· download Ghostscript 8.13 noFPU from http://www.whoosh777.pwp.blueyonder.co.uk/ and install anything needed, set all assigns, and do not forget to download the MorphOS-Magic stuff which contains of the gs-handler and the PS: dosdriver
· copy "gs-handler" to l:
· copy "PS" to devs:dosdrivers/
· assign Ghostscript: gs813:
· in Turboprefs for MOS, use the following command line in the PS-Section:
"ghostscript:gs -dDEVICE=tp24 -dBATCH -dNOPAUSE -q", and set the density cycle-button to anything else than "as in Config"
With these steps all my PDF printig problems are gone.
You might take a look to the following page for screenshots of Turboprefs:
http://roschmyr.gmxhome.de/Drucken_PS-PAR/
Happy PDF-in-color-from-APDF-printing
Best Regards,
Schlonz
