apache & thttpd on MorphOS 1.4
    zhulien
    Posts: 139 from 2004/8/21
    hi,
    I have downloaded and installed both apache and thttpd on Morphos 1.4
    running Genesis 1.0.4 TCP stack.
    I have had inconsistant success in serving basic HTML pages with
    Apache (sometimes it works, sometimes it doesn't). So, I figured I'd
    try thttpd. For some reason, both programs appear to do similar
    things, they start, after a few seconds, they terminate. Watching
    thttpd startup with snoopdos indicates that the paths are found, I
    have left the default user as nobody (but I have also tried a www user
    that I had setup for Apache). So far I haven't managed to serve a
    page at all with thttpd.
    Is there anything obvious that I must be forgetting to do for this
    irratic behaviour?
  • »09.10.04 - 15:19
    Robin
    Posts: 741 from 2003/2/24
    Which apache version did you try ?
    There are some online that are known to not
    work correctly ... and it would help if
    you could show your httpd.conf .
    I never tried thttpd because apache runs
    really great here ... I've even managed to compile
    it with the help of tokai myself :)
    http://my.morphosi.net/mnet.pl?mode=hw&category=Misc&name=Compiles
  • »09.10.04 - 15:27
