EASY LINUX INSTALLATION...WHEN???
    Elektro
    Posts: 202 from 2004/2/3
    An EASY Linux distro for stupid as me,WHEN???
    Gentoo...terrible hard,
    Debian..."lassamo perde"...about 50 diffetrent installer tryed and no-one worked...
    Now I'm trying the Crux2.0....and it's possible only if you are engineer...  :-x
    A simple distro..WHEN???I'm asking too much?
    Something as Mandrake for x86...
  • »06.10.04 - 13:31
    Hawk
    Posts: 204 from 2003/12/29
    I installed Debian this week, and if you follow the default steps is not hard. Here is some help:
    Debian installation
    I used Gentoo before and well... yeah, it can be hard sometimes ^^;
    Pegasos II G3@600Mhz (no fan) 512MB RAM (1 slot)
    -- Maxtor 6Y120P0 120GB, 7200 rpm -- ATI Radeon 7500 - (64MB, TV-out)
    -- Minuet Slimline PC case -- MorphOS 1.4.5 + Gentoo
    EFIKA
  • »06.10.04 - 14:07
    DSLCC
    Posts: 246 from 2003/5/14
    I've had similar frustrations. Ended up getting PegXLin and PegXMac to run MOL. Then gave up in frustration and got a real Mac. :) Now I'm hooked on OSX while I wait for MOS 1.5. Right now the Peg is in the closet.  :-)  :-D  :-o
    Pegasos 1 G3 MorphOS 1.4.5* Mac G4 Sawtooth 1Ghz Tiger 10.4.1* Both Rock! :-D
  • »06.10.04 - 17:08
    Posts: 199 from 2004/2/9
    At SNDF the image installer team showed a Linux installer. It works fine and it is very easy. I don't know where to get it but have a look at their website...
  • »06.10.04 - 18:21
    Posts: 918 from 2004/1/24
    Before someone is going to say: "where's the link?"
    http://www.amipeglin.de.vu/
  • »06.10.04 - 18:35
    ButterflyKisses
    Posts: 85 from 2004/3/10
    the new yellow dog has the anaconda installer and it is a painless install
  • »06.10.04 - 21:40
    Thanks Stevo :)
  • »07.10.04 - 13:51
    artickfox
    Posts: 101 from 2004/4/17
    A: Debian is installable via CD on Pegasos 2 ONLY with SARGE release, for now avaiable on "testing" directory:
    http://cdimage.debian.org/pub/weekly/powerpc/
    (Why everyone have forget to say what release is actually bootable?)
    USE THE INSTALLER INTO "POWERPC" DIRECTORY (vmlinuz-chrp.initrd), becouse is the only one wich run!
    If you encounter some problem, sometimes are a CD Image bad burn or a bad download. Better try to remake a 2 time the CD before think if is something into Pegasos to not work.
    B: Gentoo is well usable only if you have a serious internet connection. Portage need to costantly updated for mantaing it's packages, and if you haven't last release become HARD install something on it. Alternatively you must everytime manually install Portage on machine.
    Using Debian or Crux is lesser time-wasting if you don't have net connection.
    C: The last release of CruxPPC 2.0 seem have some problem to boot on Pegasos 2... :-o
    Virtual Paws:
    http://www.furryitalia.net/virtualpaws/index.htm
    Italian furry videogame site
    Furry Italia
    Italian Furry Comunity
    - Owner of a Pegasos 2/G3 -
  • »07.10.04 - 21:18
    minator
    Posts: 371 from 2003/3/28
    Oddly enough I'm in a Linux distro group who are targetting this area, it's only x86 at this point but I'll see about getting it onto the peg if / when i get hold of one.
    I'm in charge of the installer so if nothing else it should have the easiest Linux installer in the business.
  • »08.10.04 - 10:11
