question about MorphOS
    James
    Posts: 110 from 2004/9/26
    Hello everyone!
    I was looking at the MDC site last night, and I could not find what I was looking for. Are there any user interface guidelines when programming for MorphOS?
    BTW, the Halloween graphics are really funny. :-D
  • »03.10.04 - 14:12
  • jah
    jah
    Posts: 69 from 2003/3/24
    look into the sdk archives, in the documentation directory you will
    find some MUI exemples
  • »03.10.04 - 14:20
    James
    Thanks for the info! :-)
  • »03.10.04 - 15:02
    Posts: 1521 from 2003/2/24
    Not really. Someone should write one...
  • »03.10.04 - 19:57
    Tcheko
    Posts: 544 from 2003/2/25
    http://www.guru-meditation.net/main.php3?newsid=217
    Someone wrote it. But in french.
    Hope this will help.
  • »04.10.04 - 05:14
  • News Moderator
    News Moderator
    Darth_X
    Posts: 571 from 2003/2/10
    BOUNTY!!!! :-)
    [ Edited by Darth_X on 2004/10/4 0:41 ]
  • »04.10.04 - 05:21
    James
    BOUNTY!!!! :-)
    I will have a peek at it tonight. I understand a bit of French (Canadian), so I might be able to figure it out. :-)
  • »04.10.04 - 21:54
