MiamiDX keys latest version but MiamiDx wants me to register
    MrZoon
    Posts: 48 from 2003/6/1
    This is wierd, especially as I did this before, successfully. After losing the main HD on my Peg I, I swapped in a spare and am reconfiguring things. I installed MiamiDX, and transfered the reg keys from my old machine. When I start MiamiDx, it appears to be unregistered, as the Register button is active. But when I try to register, MiamiDx sez my keys are the latest version, and I don't need to register!
    Any ideas or suggestions are welcome...
    Also, has anyone experienced (unexpected) fatal HD failures on Peg I with MorphOS 1.4? This was a Maxtor 36GB drive with little use. It was working fine a couple of weeks ago, then one day when I turned it on, it just started clicking. I tried reformatting it in a PC I keep around for hw testing, but it wasn't even recognized, much less formattable.
    Pete
    [ Edited by MrZoon on 2004/9/28 15:18 ]
    MrZoon ~8
  • »28.09.04 - 20:15
    Motosampy
    Posts: 199 from 2004/8/14
    I've had always the 'Start Register' button active eventhough I have valid keys installed...
    If it works over 30mins then everything is most likely ok...
  • »28.09.04 - 20:31
    MrZoon
    or would be if half the features weren't disabled.
    MrZoon ~8
  • »29.09.04 - 04:10
