                Posts: 641 from 2004/1/25
Quote: in AHIRecord are more inputs available... just check it out and see for Yourself.
I don't really understand you here. If the hardware only has one input, how can the software create more? (Sorry if this is a stupid question.)
Well, I don't remember it exactly (I haven't it in front of me), but iirc, also audio outputs can be used as inputs...  it means, that You can record what You are playing... and there isn't the only one input, there are CDROM, line in and microphone inputs... But I'm talking here only about the SB Live...
I successfully recorded sound from my YAMAHA keyboard and some speach by microphone without any wire swapping
btw: just check it out, and see for Yourself
Bye, MarK.
PS: I will check it tonight and tell more later.
