I have confirmed that OS 9 has no problem with partitions greater than 8GB. This is unfortunate for the OS X side. Of course, using a second partition for apps, etc. is doable as a work-around. I prefer to keep it all on one drive myself. :)
The partition limitation is minor compared to another problem I have-- I lost ethernet! This worked just fine on PegXMac 1.0. If fact, I didn't even have to configure it before. Now, I keep getting an IP address in the range of 169.x.x.x assigned to me. Obviously, it is not talking to my router.
Anyone know where I should be looking to correct this? When PegXMac starts, it briefly mentions using eth0 before the MOL menu appears, which I believe corresponds correctly to the 100MBps ethernet port on my Peg II.
I've checked the configmolrc.net file and it appears correct, but like I said, I didn't even have to modify this with PXM 1.0. I also tried running etherconf and said Yes to using DHCP and then received a "failed" message. Hmmm.
USB and mice-- does this work? I believe I have modified the configmolrc.input file correctly but none of the three USB mice I have tried are working. PS/2 is okay, but I happen to hate the one I've got connected right now.
Sounds is a problem, also. I was successful obtaining poor quality through the Peg's built-in audio in the past but now would like to use my SoundBlaster Live with MOL. Is this possible?
[ Edited by jdryyz on 2004/8/15 11:00 ]
