YAM removed links
    pegasosuser
    Posts: 138 from 2004/4/9
    if I picked up with the program YAM my e-mail, and read my mail and
    appear there a link in reported b.v.: 'https://morph.zone' then
    the link is removed that then never gets I to see.
    but I look at standing by means of Voyager to my mail then leftthere,
    however, in but I will pick up them later by means of YAM than have
    been leftremoved.
    who know does this problem?
    greetings Cor van Londen.
    PEGASOSII G4@1Ghz Registered MorphOS2.5 & AmigaOS4.1 1024DDRam ATI RADEON9250-256Mb(128Bit) Creatieve Soundblaster Live! 2 x HD MAXTOR U-ATA133 160Gb 8Mb-Cache Plextor DVDR +- RW 708A 2Mb Buffer ONLY PEGASOS MAKE IT POSSIBLE!
  • »11.09.04 - 04:45
    Posts: 1084 from 2003/3/24
    Try to set in Yam another color for the URL!
  • »11.09.04 - 14:21
    tarbos
    Posts: 221 from 2003/4/19
    Wow, this is really hard to understand.
    I only experienced "removed links" in an e-mail when I got a reply back which had the links marked with the backgroundcolour, so it was not removed at all, just not visible. I don't know if this is your problem, but mine was easily solved by changing the colour in the prefs for mail reading.
  • »11.09.04 - 15:01
    pegasosuser
    TNX!
    I can now see the link
  • »11.09.04 - 20:02
