Sample Manager
    Robert
    Posts: 331 from 2003/5/12
    I tried out the programme 'Sample Manager' last night.
    It appears to work well but seems to be restrcited to 32mb RAM on my Peg1. (I appear to have 80mb free)
    I can't find anything in the docs except that 64mb RAM is reccommended.
    Anyone else used this programme and encounter a similar problem?
    Thanks,
    Robert.
    Robert.
  • »07.09.04 - 07:58
    Posts: 918 from 2004/1/24
    Well, I have a peg1 myself, and never encountered any problems with Sample Manager.
    Don't know if you tried, but...you have to set the amount of memory available to Sample Manager in it's preferences. :-)
  • »07.09.04 - 08:05
    Robert
    I had a look in prefs and all I could see was 'undo buffer', which was set to 32mb.
    I tried upping this to 64mb but it then shows as 1mb! :-?
    I can't check it just now (at work) but I'll have another look tonight.
    Robert.
  • »07.09.04 - 10:29
    igracki
    Posts: 469 from 2003/2/24
    This was a bug in the old version!
    Its fixed in the current version 1.3 (15.05.04)!
  • »07.09.04 - 17:38
    Robert
    Yup, thanks Igracki.
    I got your email from the MorLOUD list.
    Will try again tonight.
    :pint:
    OT:
    Is there a decent programme for recording sound input that anyone knows?
    (I've been using PSA but there is no monitor.)
    Thanks again folks,
    Robert.
    Robert.
  • »08.09.04 - 06:35
    roschmyr
    Posts: 211 from 2003/2/20
    @Robert
    try AHIrecord
    http://www.toms-home.de/Software/AhiRecord-1.8.lha
  • »08.09.04 - 07:40
    Robert
    roschmyr wrote:
    @Robert
    try AHIrecord
    Will do, cheers.
    [ Edited by Robert on 2004/9/8 14:26 ]
    Robert.
  • »08.09.04 - 08:35
    Robert
    Downloaded 1.3 last night and it worked a treat except for one thing: It doesn't appear to flush the memory after use, even if I exit the programme.
    I have around 80mb free after booting and edited a 50mb sample, then found the only way I could edit another was to reboot.
    (Apologies if there's an obvious menu item to flush memory - I only had ten minutes to play with it before heading to the match.)
    Robert.
  • »09.09.04 - 06:42
