Getting a Nikon Coolpix 3200 to work?
    td741
    Posts: 224 from 2003/4/2
    I've recently upgraded my camera (I had an older Olympus Brio 1.33 megapixel.)
    Anyway, I can't seem to get the camera to work with Poseidon.
    I tried it in Mass storage device mode and I keep getting a command failed message in Trident... (don't have the exact string with me as I'm away from my Peg)
    I've switched it to PTP mode and grabbed the PtpDigCam driver/software and the most I got from it was the time from the camera. Everything else throws a "Command Error". :P
    Anyone have any hints?
    Thanks,
    Steph
    Steph
  • »02.09.04 - 21:53
    saragaglia
    Posts: 12 from 2004/9/3
    I have the same camera, and I did not succeed in using it with poseidon... :(
  • »03.09.04 - 10:19
  • scf
    scf
    Posts: 54 from 2003/6/3
    I have Canon A70 and it works with ptpdigcam, not 100% yet but I able to get images from camera.
  • »03.09.04 - 11:40
    ChatDEau
    Posts: 248 from 2003/4/4
    @td741 & saragaglia
    I'd suggest you write directly to the author of PtpDigCam, mention your camera brand, model and what goes wrong as well as a debug log if you can provide it to him.
    He'll surely be happy to get some feedback from users like you and may even be able to add support for your digital cameras.
    His email is rmais96 (at) free.fr
    Hope it helps!
    Fred
  • »03.09.04 - 15:19
    Druideck
    Posts: 82 from 2003/5/6
    I use a candu CR-217A mass storage card reader,
    it works great on various camera cards and
    functions as a memory stick for transferring
    files to PC's etc.
  • »04.09.04 - 11:14
