Setting up UAE on Peg II.
    matt3
    Posts: 785 from 2004/2/10
    I can't get UAE to run on my Peg II with MOS 1.4.1. I have tried multiple versions of UAE and still the same results... Nothing.
    I modified the cfg file to point to my roms.
    Any help is greatly appreciated...
    Matt
  • »31.08.04 - 17:30
    Posts: 1933 from 2003/10/19
    You need the libs for MUI REXX installed. I found the best way was to go and get the latest build DJBase did. Do a search here and you should find a link to it in a recent post.
    [ Edited by Acill on 2004/9/1 2:52 ]
  • »01.09.04 - 07:51
    Posts: 921 from 2004/1/24
    We still need an updated MOS native UAE build with decent sound support...and a decent gui!
    ...now where was that bounty thread....;-)
  • »01.09.04 - 09:54
