New MPlayer out
    Posts: 236 from 2003/7/28
    There was a new version of MPlayer released for MorphOS, but I didn't see any news of it here...
    Just go here:
    http://www.pegasosforum.de/viewtopic.php?t=806
    HammerD
  • »26.08.04 - 23:41
    hooligan
    Posts: 1948 from 2003/2/23
    What I have seen and heard, it's actually a step back from 0.91, so better stick to it for awhile :-)
  • »27.08.04 - 02:48
    DJBase
    Posts: 745 from 2003/4/6
    Hm, it works like it should. See no problems.
  • »27.08.04 - 05:09
    Jupp3
    Posts: 1193 from 2003/2/24
    8bit audio seems to work now (Sounded all wrong on earlier version)
  • »27.08.04 - 05:49
  • Lee
    Lee
    Posts: 70 from 2003/4/9
    Have someone try DVD and VCD?
    It dont work here??
  • »27.08.04 - 06:37
    warface
    Posts: 653 from 2003/2/24
    DVD handling has changed, check the readme. Didn't tried it yet, though, just a suggestion. :-)
  • »27.08.04 - 07:10
  • Leo
    Leo
    Posts: 425 from 2003/8/18
    Direct link: http://nogfx.free.fr/morphos/MPlayer10-PRE4.lha (2Mb)
    Website: http://nogfx.free.fr/warpdesign/soft_muifind.html
    Sources: see readme
    Regards,
    Leo.
    [ Edited by Leo on 2004/8/27 9:51 ]
  • »27.08.04 - 07:50
    thefab
    Posts: 92 from 2003/8/19
    hi,
    as you can see, it's still a beta, so don't complain about any bugs as
    it will surely change with the final release.
    the changes which i've noticed are a better compatibility with some
    codecs (for exemple .mkv and .ogm are now supported)
  • »27.08.04 - 09:02
    tokai
    Posts: 1289 from 2003/2/25
    .ogm and .mkv are not codecs, but container formats.
    ANd .ogm is supported just fine with 0.91 too. And for .mkv there are mkvtoolnix ported to morphos already. :-)
    regards,
    tokai
  • »27.08.04 - 09:12
    thefab
    hmm, .ogm are supported in 0.91? then it's a bit strange that when i
    try one of them, i get video only, or nothing, or a big crash.
    No more problem with this pre4.
    as for mkvtoolnix, hmmm, it will take me ages to convert all of my
    .mkv ;)
  • »27.08.04 - 09:20
    tokai
    .ogm files can contain different types of videos, audio etc. which can use different codecs. So you probably have a ogm file with an audio track which uses a codec whcih does not work properly in 0.91.
    The few .ogm files I have here work just fine with 0.91, only subtitles are a bit desynced in .ogm files.
    regards,
    tokai
  • »27.08.04 - 09:32
    Amano
    Posts: 1 from 2004/2/19
    The new MPlayer... great work!
    It plays the mkv-s!!!
    I was able to play most of my ogm-s with 0.91, but now, I don't have to split-and-join the mkv movies.
    Thanks for your work!
  • »27.08.04 - 13:34
    Frostwork
    Posts: 302 from 2003/4/18
    Hi!
    GREAT!
    Thank you very much for the (almost up2date) port!!!!
    BTW: If you're looking for an actual debian version check out:
    http://honk.physik.uni-konstanz.de/~agx/linux-ppc/debian/mplayer/
    bye
    frostwork
  • »27.08.04 - 16:25
