Sort by national ABC
    GK_LKA
    Posts: 481 from 2004/3/28
    Does the locale-system support sorting by the selected country's own ABC? We, in hungary have special characters like á and é. For example á is between a and b in our ABC, but the filenames starting with á are at the end of the file list.
    [ GK / LKA Team ]
  • »16.08.04 - 23:04
    tokai
    Posts: 1289 from 2003/2/25
    dunno if locale supports such stuff at all, but i think sorting is done by using the ascii table. ANd then é or á is somethere behind the normal (latin) letters.
    regards,
    tokai
  • »17.08.04 - 06:03
    Piru
    Posts: 619 from 2003/2/24
    @GK_LKA
    Yes. See locale.library function StrnCmp (SC_COLLATE1 and SC_COLLATE2).
    This is supported by the locale system, and for example 'sort' command uses locale for sorting.
    [ Edited by Piru on 2004/8/17 12:29 ]
  • »17.08.04 - 07:26
    GK_LKA
    You have right. It seems that the hungarian language file is wrong, and it uses the ASCII table for sorting instead of our ABC.
    [ GK / LKA Team ]
  • »17.08.04 - 20:18
