MorphOS Crash (update)
    Posts: 236 from 2003/7/28
    Ok, I just upgraded my hardware to a Pegasos 2 G4 ....very nice system! Thanks Genesi and my dealer, GGS!
    Previously I had a Pegasos-1 with april2 fix.
    Curiously, I am still getting a similar crash when using ANR to stream shoutcast from the net and doing other things (mostly, web browsing with Ibrowse). I have MorphOS 1.4.2 and the newest AHI installed.
    I have 512 meg of RAM in my Peg-2, so I was able to save a large debug log (thanks to tokai :). I have put it on my website.
    If any programmer out there can determine what caused the crash, I would be extremely happy! The last thing I did was soft-reset the machine and then save the crash log to a file.
    The crash log is HERE: http://www.ody.ca/~develand/crasher.lha
    Thanks alot!
  • »14.08.04 - 03:37
    Posts: 1931 from 2003/10/19
    Strange, I stream ANR all the time if i am at my Psegasos II. I use the web, type in wordworth and MorphED, sometime play a game even with no problems at all. What did you do to restore your system after the upgrade? i think you may have moved a bug over from your old system to the new one if you used a backup. Maybe you should try to rebuild your system from scratch again?
  • »14.08.04 - 10:18
