Strange bochs error
    artickfox
    Posts: 101 from 2004/4/17
    I have a strange error whith Bochs for MOS. When i try to run it, it stop and give me a "rombios panic" error. It start, but stop immediately to run and give me this error.
    I try to change options, but it still don't work.
    Someone can give me some help?
    Virtual Paws:
    http://www.furryitalia.net/virtualpaws/index.htm
    Italian furry videogame site
    Furry Italia
    Italian Furry Comunity
    - Owner of a Pegasos 2/G3 -
  • »11.07.04 - 08:10
    Spidey
    Posts: 568 from 2003/2/24
    Hi artickfox,
    Did you try my guide of installing Bochs?
    Don't know if it's still here on the site.
    Hmm, check my website and click on the Bochs guide on the left.
    Look at the configuration-part.
    Hope it helps.
    Bye,
    Spidey
  • »12.07.04 - 11:43
    artickfox
    Yes, I have use your guide, your configuration files, and installed anything what is suggested in the guide, I try also to install Bochs more time.
    Also, I have downloaded Bochs where you have suggested...
    But this error still here!
    Maybe my Pegasos is angry whit me becouse I want run Windows on it?
     :-o  :-o  :-D
    Virtual Paws:
    Furry Italia
  • »12.07.04 - 13:37
    Spidey
    Hi artickfox,
    That's strange indeed then!
    Send me your configuration (private mail) and I'll look into it.
    Otherwise it could be a faulty bios-rom :-?
    Bye,
    Spidey
  • »12.07.04 - 14:30
    Posts: 261 from 2003/3/13
    Mabe his download was corrupted, and
    damaged the bios.
    Anyway, it's time for a up to date bochs version
    if you ask me.. need speed/sound/network :)
    I will update the GUI when a new version will
    become available.
    Gr.
    Felix.
  • »12.07.04 - 15:06
    artickfox
    mmm... i will look if is a corrupt bios... in fact now i have remember which I haven't try to download it again.
    Virtual Paws:
    Furry Italia
  • »12.07.04 - 15:34
    Spidey
    @Felix:
    That would be cool! :-D
    And yes, I totally agree with you about the needed options.
    @artickfox:
    Keep us posted :-)
    Bye,
    Spidey
  • »12.07.04 - 16:21
    Posts: 1087 from 2003/3/24
    @ Felix: Yes, better support for Videomodes like 1024x768 and up in 24bit.
  • »12.07.04 - 21:25
    artickfox
    Nothing. I re-download Bochs and I try to run it, but I have again same error:
    "[BIOS ] BIOS panic at Rombios.c, line 1563"
    Seem there is nothing to do with configuration file: i have put a minimal configuration (set only HD type and dimension) but error is ever same.
    Also, I have make no changes to MorphOS (no other third part software running or a custom Startup-Sequence, only OS).
    Well, I don't understand why it don't want run...
    Virtual Paws:
    Furry Italia
  • »18.07.04 - 12:26
    Very strange...
    I lost my whole Bochs setup because i had a HD crash,
    but mabe a MZ user can mail you a working bochs achive.
    Gr.
    Felix.
  • »18.07.04 - 16:33
    artickfox
    Maybe on Zargos.net have a corrupted Bios?  :-?  :-?  :-?
    Virtual Paws:
    Furry Italia
  • »18.07.04 - 18:10
    tokai
    Posts: 1289 from 2003/2/25
    it is not. You make for sure something wrong.
    make sure you have this in the bochs ressource file, and
    also make sure you have this BIOS file there.
    # ROMIMAGE:
    # You now need to load a ROM BIOS into F0000-FFFFF. I've wiped
    # out most of the BIOS hooks, and replace them with real BIOS
    # support. Normally, you can use a precompiled BIOS in the bios/
    # directory, named BIOS-bochs-latest.
    romimage: file=bios/BIOS-bochs-latest, address=0xf0000
    regards,
    tokai
  • »18.07.04 - 20:02
    artickfox
    Yes, is in the archive, and I look well options... I try also other BIOS file, but I have same error.
    Virtual Paws:
    Furry Italia
  • »18.07.04 - 20:09
    Spidey
    Hi artickfox,
    I'll mail you my Bochs and config this evening by mail. :-)
    Bye,
    Spidey
  • »19.07.04 - 04:21
    Spidey
    Hi artickfox,
    Check your mail ;-)
    Spidey
  • »19.07.04 - 15:56
    artickfox
    Today i try again whith Spidey's files, but I have again same error. I don't think is a OS problem. Maybe some of my hardware is not compatible with bochs?
    Virtual Paws:
    Furry Italia
  • »06.08.04 - 16:09
    Spidey
    Hi artickfox,
    I just send you my SnoopDOS log while starting up Bochs.
    Hopefully this is some kind of help :-)
    Bye,
    Spidey
  • »07.08.04 - 05:17
    klapdeur
    Posts: 132 from 2003/6/28
    man i have the same error as artifox here got anything found yet
    anybody to solve this error ??
    by the way i got it running now but i cant use mos if bochs is running and the reset and power buttons on bochs i cant use them either.
    so i have to reset my peg to use mos again.
    [ Edited by klapdeur on 2004/8/10 23:21 ]
  • »09.08.04 - 21:43
    Spidey
    Let's wait until artickfox has compared the SnoopDOS logs.
    I hope something usefull comes out of this, I really don't know why Bochs doesn't work with you two :-(
    I followed my own guide, with the exeption that I already had installed fat95 (and that other prog) on my harddisk, so when I installed the Bochs GUI of Felix it wasn't necessary to download them again.
    But these files aren't important for Bochs to work.
    Hmm, I've got an empty partition. I'll install a clean MorphOS on it with Bochs, unfortunately I'm busy this week, so I'll try it next week.
    Bye,
    Spidey
  • »10.08.04 - 06:18
    artickfox
    I give a look to SnoopDos, but I haven't enough competence to understand what's going wrong...
    Howerer, for now i need to install Linux on Pegasos, so for long tme I will have time to try again with Boch - MorphOS...
    Virtual Paws:
    Furry Italia
  • »10.08.04 - 09:11
