bochs gui MUI problem
    klapdeur
    Posts: 132 from 2003/6/28
    hi guys i try to run bochs gui but it salways comes with the message
    that i have to install the intext.mcc class but i allready have that
    installed can you guys help me out here what to do to get the gui
    working ???
  • »06.08.04 - 23:54
    Spidey
    Posts: 568 from 2003/2/24
    Hi klapdeur,
    I don't have a intext.mcc on my Peg :-?
    Perhaps you mean Infotext.mcc?
    I've got version 15.3 and it's in the Classes:MUI-dir.
    Which GUI do you use?
    Bye,
    Spidey
  • »07.08.04 - 07:58
    klapdeur
    well that what i mean im using the gui from attention software site.
    is there another gui to use then ???
  • »07.08.04 - 09:09
