How covert mp3 to ogg?
  • Lee
    Lee
    Posts: 70 from 2003/4/9
    how can i convert mp3 to ogg filesunder mos?
    Knows anybody a tool to do this?
    thx
    lee
  • »31.07.04 - 15:44
    Posts: 1087 from 2003/3/24
    Try Ripper 2.51!
  • »31.07.04 - 16:29
    hooligan
    Posts: 1948 from 2003/2/23
    But why would you want to rape the sound twice instead of only having it raped once? :)
  • »31.07.04 - 16:38
  • Lee
    Lee
    @theplayer
    Thanks for the hint! I use this tool already but not to convert files.
    Ripper is cool! :-)
    @hooligan
    You find more mp3 than ogg with MLdonkey. ;-)
  • »31.07.04 - 17:22
    brotheris
    Posts: 142 from 2003/2/24
    After conversion sound quality will be worse.
    Home sweet home is Pegasos User Group Lithuania
  • »31.07.04 - 17:29
    merko
    Posts: 328 from 2003/5/19
    Use Ripper to encode your CDs to OGG. It rules.
    But as people have pointed out, converting mp3 to ogg is generally not
    a good idea. Maybe if you want to significantly lower the bitrate at
    the same time, so that you're already expecting a quality loss.
    I don't know of any device that can play OGG, that can not play mp3,
    so it's usually best to leave mp3 files in that format. :-)
  • »31.07.04 - 18:13
