Zip & Unzip....
    Elektro
    Posts: 202 from 2004/2/3
    Hallo,
    I've downloaded the ZipMos from Aminet...with this everytime i've try
    to unpack archive,it extract damaged files!!!
    There is a better version of unzip???
    Tnx
  • »30.07.04 - 21:54
    td741
    Posts: 224 from 2003/4/2
    My version of Zip keeps unsetting the protection bits. It's quite annoying... Although nothing a quick call to protect with wildcards and "all" can't fix quickly. :P
    How are your files damaged?
    [ Edited by td741 on 2004/7/30 18:26 ]
    Steph
  • »30.07.04 - 22:26
    killlbilll
    Posts: 95 from 2004/5/19
    Yes, the files may seem damaged when copied from a state where there are no protection bits set. I've done this a couple of times: Upacked a zip-archive using unzip, then moved/copied the files using Dopus. Dopus will create empty files in the destiation dir because it is not allowed to read the files. I don't know if there exists a unzip which fixes this problem, but you can make a script that automatically sets protection bits on the upacked files (in eg. Dopus).
    [ pegasos ii / g4 | morphos1.4.4 ]
  • »30.07.04 - 23:09
    Druideck
    Posts: 82 from 2003/5/6
    I use Unzip.lha on aminet. It also changes the protection bits :(
    I use Dopus to change the bits when necessary.
    Any other solutions?
  • »31.07.04 - 08:09
    GK_LKA
    Posts: 481 from 2004/3/28
    I use UnZIP 5.40, maybe 68k, I don't know, but I never had any problems with it.
    [ GK / LKA Team ]
  • »31.07.04 - 13:41
