Posts: 2095 from 2003/6/4
Miky060 wrote:
as you can see dholm words comfirm what I sayd: 3D drivers only for the old 7xxx serie.
Well, if only for RV100 then it' ll be only for 7000 and 7200. The 7500 uses the same chip as the 8500 and 9100 does, namely the R(V)200. The R(V)200 is IIRC quite similar to the R(V)100.
The RV250 might be different, therefore I put it into brackets. But If my brain doesn't fool me too much it's been stated somewhere that there is 3d support for other ATI's than only the 7000 and 7200 (iirc for the R(V)200 series).
Difference between 7500 and 8500 and 9100 is that the 7500 uses an RV200 and the latter both are using R200 chips which include additional Pixelshaders.
[ Edited by Zylesea on 2004/7/28 15:45 ]
