Bootcreator Problem
    Leon
    Posts: 93 from 2003/11/28
    as in the bootcreator readme, I have created a Forth script:
    >Bootcreator explict menuscript
    and copied the file menuscript into my FFS boot partition. Then at OF prompt:
    >setenv boot-file menuscript
    boot-file=menuscript
    Everything is OK so far.
    But the OF is just booting into the command prompt. The boot menu is not appearing. Should I do anything else?
    Regards
    Leon
    Proud owner of:
    Efika
    ABIT ATI 9200SE AGP 128MB
    40GB Samsung Hard Drive 5400rpm
    PowerMac 3.1 G4 350Mhz "Sawtooth" AGP
  • »28.07.04 - 20:44
    tokai
    Posts: 1289 from 2003/2/25
    first make sure you script works:
    enter:
    boot menuscript
    into OF and see if it comes up and works. If not then fix.
    But I think you just forgot to enable auto-boot (again).
    regards,
    tokai
  • »29.07.04 - 00:32
    Leon
    My bootscript works. I tested it via:
    boot /pci/ide/disk@0,0:0 menuscript
    (I don't know why I have to type the full command, some people simply type boot menuscript and it works?)
    And tried to enable auto-boot like this?
    setenv auto-boot? true
    It seemed it works but this time I get strange characters:
    RRRRRR...
    Proud owner of:
    Efika
  • »30.07.04 - 15:21
