AHI 5.13 Problems!
    Posts: 1087 from 2003/3/24
    Today i've installed AHI5.13 but my problem is that the soundvolume is now very low with 32 Channels and with 2 channels it is also to low.
    Has someone the same Problem or knows how to fix it? With an older version of AHI i had no problems with the volume.
  • »27.07.04 - 22:06
    Posts: 1521 from 2003/2/24
    Use AHI prefs from the package to edit settings. There is new "Volume scaling" option, try change it.
  • »27.07.04 - 22:09
    I have found the Problem, it was the catalog files for the new Prefs in German the Text for the Volume Scalling button is missing!
    [ Edited by ThePlayer on 2004/7/28 12:26 ]
  • »27.07.04 - 22:43
