Mplayer and .ram & .wmv
    Elektro
    Posts: 202 from 2004/2/3
    Where can i get codecs (if exists) for Mplayer to show Real files and
    WindowsMediaVideo?
    Tnx
  • »25.07.04 - 18:56
    Posts: 918 from 2004/1/24
    Well, I can't say about realplayer files, but wmv is a storage format for all sorts of codecs (if I'm not mistaken); therefore some wmv files work...but alas, most won't
  • »25.07.04 - 19:11
    dholm
    Posts: 296 from 2003/9/1
    WMV1, WMV2, WMV7, and WMV8 should work since they are supported by libavcodec. The formats that will not work are WMV DMO and WMV9 DMO since they require win32 DLLs (which will only work on Linux/x86).
    As for realmedia you will need the codecs from the Linux/PPC version of realplayer. Although I don't know if the MorphOS version of MPlayer currently support this?
    [ Edited by dholm on 2004/7/26 11:06 ]
  • »26.07.04 - 07:05
