Peg 2 Peripheral device
    Posts: 199 from 2004/2/9
    I noticed lot of people of post concerned peripheral.
    A list isn't available yet but all user could make it by simply giving the list of peripheral running on their own system.
    The web-team will be able to add all this useful information on the "quick" help section :)
    Thanks !
    T
  • »21.07.04 - 12:31
    27 views and no post :( Anyone run a Pegasos 2 ?
  • »21.07.04 - 14:56
    Posts: 81 from 2004/3/20
    I haven't had too much luck running any usb peripherals, including printer, on the Peg 2. The closest I've gotten is using my printer under CUPS in Linux.
    Harry
    Config: Pegasos II G4 1ghz, 1024mb memory,
    Radeon 9200,160gb hd total, Sound Blaster Live!
  • »22.07.04 - 18:15
    tokai
    Posts: 1289 from 2003/2/25
    HP DeskJet 400 (parallel port printer) : works
    Saitek P880 Dual Analog Joypad (USB) : works
    Cherry M-5000 USB/PS2 mouse : works
    Cherry Standard Keyboard PS2 : works
    LAKS 32MB Clock/USB Memory stick : works
    Sanyo VPC-AZ3EX 4.0 MegaPixel Digital Camera (USB) : works
    SDTA 300Watt Multimedia Speaker (Stereo) : works
    sorry, i do not have more periphials, but maybe this helps you. :-) Maybe others can post a list of tested and working equipment too.. so we can compile/update a/the list.
    regards,
    tokai
    [ Edited by tokai on 2004/7/22 19:25 ]
  • »22.07.04 - 18:24
    magnetic
    Posts: 2129 from 2003/3/1
    Tokai: thanks
    Ok here goes:
    1. Kodak dx3500 digital cam (usb) works (not mass storage with ptp digicam)
    2. Logitech Dual analogue USB joystick - works
    3. Logitech mini optical mouse USB - works
    4. Zippy IR wireless kybrd mouse ps/2 -works
    5. Logitech IR wireless kybrd mouse ps/2 - works
    6. Memorex 128mb USB Stick - works
    7. Creative Nomad MuVo 256mb MP3 player/USb stick - works (nice with ANR radio)
    8. Radio Shack PS/1 to usb joy adaptor - NOT WORKING :-(
    I've actually had most all usb mice and keyboards work as well as media sticks and card readers. Also many digital cameras work out of box as well..
    The Posiedon stack is one of the best on ANY platform IMO
    magnetic
  • »22.07.04 - 18:32
  • JKD
    JKD
    Posts: 456 from 2003/4/4
    Hey mag,
    can I ask you to clarify 'works' relating to the joystick USB type devices. I have a hell of a problem getting them to work with either UAE or MAME. In fact the only way to get MAME working seemed to be with a gameport gamepad.
    Appreciate any help..
    Steve
  • »22.07.04 - 18:42
    tokai
    @JKD: make sure you have latest poseidon installed (platon42.de) and make sure you 'merged' (or owerwrite) your USB Joypad with a lowlevel.library port (mostly you will use 1) in the poseidon settings.
    regards,
    tokai
  • »22.07.04 - 18:47
  • JKD
    JKD
    Hi tokai,
    I was able to install the new classes etc. but I believe the core reside in boot.img?
    I do not understand your 'merged' comment...maybe I missed an option in Poseidon prefs somewhere?
    Thanks,
    Steve
  • »22.07.04 - 18:49
    ironfist
    Posts: 254 from 2004/4/22
    Hi!
    We have an USB accessories list in our Wiki at Pegasos.org.
    You may of course use this list. They have all been
    tested with MorphOS.
    >> Wiki USB
  • »22.07.04 - 20:27
    magnetic
    Ironfist
    For your Kodak use the MOS native ptpDigicam - its on mz.
    magnetic
    SP?
  • »22.07.04 - 20:49
    Thank for all of you that post their list. I was expecting much more people posting but let's be happy with what we have ;) I'll do a list for Thargan to have it online ASAP
  • »24.07.04 - 14:37
    Bladerunner
    Posts: 418 from 2004/2/19
    Well ok i "just" have an Peg 1, but that should be no Problem.
    Old Synmbios logic SCSI Card, Teac SCSI Burner, Mustek Paragon SCSI Scanner, Quantum Fireball Hard Drive.
    Realteak 100 Mbit Ethernet Card.
    USB Devices:
    Cherry Cymotion Multimedia Keyboard (not the wireless Version) partial working (partial means, no support through OF, which is really bad :-( )
    Optical wireless Mouse
    Logitech Dual Action (Joypad)
    Epson Stylus C62 USB Printer, working but with know restrictions (Turboprint)
    Hama USB Hub, partial working (Weired behaviour, sometimes it just stopps to work, no USB Device connected through the hub will work, i have to unplug the hub and reconect it, than it works again. No idea why, or what triggers this failure)
    Well that`s it
    [ Edited by Bladerunner on 2004/7/24 16:14 ]
  • »24.07.04 - 15:08
