Wipeout
    klapdeur
    Posts: 132 from 2003/6/28
    hi guys how can we have cd audio on peg from the game wipeout 2097
    i just cant get any cd audio if i play this game only sound
    effects?????
  • »16.07.04 - 18:08
  • JKD
    JKD
    Posts: 456 from 2003/4/4
    Can't recall how Wipeout does it....did you connect the audio out from your CDROM drive to the input on the motherboard?
    Either that or it uses cdda.library?
    Steve
  • »16.07.04 - 20:31
    Posts: 1932 from 2003/10/19
    IT used the audio from the CD through the audio in on the motherboard or a SB live card. I had to do it that way. Same as payback on an Amiga does.
  • »17.07.04 - 03:44
    klapdeur
    i have connected it to the motherboard audio.
    but when wipeout suposed to play music my dvd-drive would start when i
    play it manuel with optyplayer i hear the music but when i finish a
    level it stops again so it had to with cd.device i gues
  • »17.07.04 - 19:15
    klapdeur
  • »17.07.04 - 19:15
