Miami demo and broadband
    Robert
    Posts: 331 from 2003/5/12
    Hi folks,
    Anyone know if the *demo* of Miami can connect to broadband?
    [Please, no answers telling me to buy MiamiDX, unless someone actually knows how to contact Holger. :-)]
    Robert.
  • »14.07.04 - 15:47
    ultraspec
    Posts: 94 from 2004/1/29
    I got the miami dx demo from aminet. It works fine, I've used in 2 different cable providers, each time behind NAT and dhcp provides the ip address.
  • »14.07.04 - 15:54
    Robert
    @ultraspec:
    Thanks.
    Is this as easy to set up as dial-up?
    Robert.
  • »14.07.04 - 16:37
    Posts: 2728 from 2003/2/24
    Miami is *very* easy to set up and use, that's its major strengths IMHO. Follow these instructions for the installation:
    https://morph.zone/modules/newbb/viewtopic.php?topic_id=1906&forum=9#16661
    ... and then try running the setup guide/wizard to set up the network. I have not used it with modem myself, only Ethernet (stopped using modems at all some years ago), but it should be as easy as ever to set up a modem connection too! Good luck! :-)
  • »14.07.04 - 18:41
