Moderator
Posts: 441 from 2003/2/26
Hi Serge
Thank You for your feedback !
I guess you mean you have your printer connected to your PC computer running Windows.
Im not sure, but as Windows have an inbuilt function for sharing the printer with other computers in the network it might work. Have not tried it so myself. I have the printer connected to a printer server in the network.
Those printer servers is not so very expensive. The good thing with this solution as I feel is that a printer server is always online, you can shut down, turn on all other computers in your network as you like, and you can print from any computer in your network as you like of course.
Most printerservers have the possibility to connect at least two printers. So you can have one printer for color printing and one for text ouput for instance.
About IP adresses;
Yes the printer server has an IP adress of course, I think I also wrote that in the text, have to check, but I usually tries to give computer or networkplaces some name. I use the name netgear for this one, as it is a netgear.
No its not possible to use the Windows-driver for printing in MorphOS. You need to have printer-driver on any computer that you would like to print from.
Hope you find a good way.
Gunne
[ Edited by gunne on 2004/7/14 11:32 ]
[ Edited by gunne on 2004/7/14 11:33 ]
Best wishes, Gunne
