Realy need help..
    Posts: 261 from 2003/3/13
    Hello,
    So we had a important task, capture our friends wedding day, and make a DVD/VCD/SVCD movie. Up till now, we used MOS and LinuxPPC.
    Attempt 1, use ffmpeg to convert the DV camera files to standart VCD format.
    Output: Useless, no CBR support.. Most DVD players stotter..
    Attempt 2, use ffmpeg to convert the DV camera files to standart SVCD format.
    Output: Useless, no CBR support.. Only some DVD players will play these files.
    Anyone, mos/linux expert please help,
    we are totally out of options..
    We also tried to 'just' burn the .dv raw data
    camera files to DVD with debian/linux. The strange thing is, we created 1 DVD containing 2 .dv files (Both arround 2 GB), but after that, we killed 5 empty DVD's. (Might be a file >4 GB problem)
    Our main goal is to create several DVD's with
    video/audio playable on all DVD players.
    At this point, we have tried all options, exept for using windows.
    Please help.
  • »10.07.04 - 03:19
    bigfoot
    Posts: 510 from 2003/4/11
    To quote the ffmpeg documentation:
    `-target type'
    specify target file type ("vcd", "svcd" or "dvd"). All the format options (bitrate, codecs, buffer sizes) are automatically set by this option. You can just type:
    ffmpeg -i myfile.avi -target vcd /tmp/vcd.mpg
    I'm sure ffmpeg can do CBR (see above), and you most definitely do not want CBR for an SVCD
  • »10.07.04 - 05:40
    Posts: 916 from 2004/1/24
    did you try MEncoder? It might be able to do the job instead of ffmpeg
  • »10.07.04 - 10:27
    Wishmaster
    Posts: 342 from 2003/6/29
    Both programs can create mpeg streams suitable for VCD creation on Linux.
    On MorphOS ffmpeg is currently the only option, because the MorphOS mencoder 0.91 version has no working mpeg support, v1.0 is needed.
    Pegasos PPC
  • »10.07.04 - 10:56
    catohagen
    Posts: 297 from 2003/5/20
    So why not do the stuff on Windows ? Save yourself many wasted hours :-)
  • »10.07.04 - 12:12
    Wishmaster
    There are numerous programs available for this task on Linux.
    No need for Windows.
    Pegasos PPC
  • »10.07.04 - 12:48
    Good idea, exept for a few minor details,
    1. Windows sux,
    2. See 1.
    No seriously, i only have a laptop, with
    less then 600 MB free, 1 DV file can be
    huge, so i have to backup everything,
    without having a cd-burn device.
    (Have one, but doesn't work, registry trouble..)
    Bye
  • »10.07.04 - 14:30
    > Quote:
    > `-target type'
    > I'm sure ffmpeg can do CBR (see above), and you > most definitely do not want CBR for an SVCD
    Thanx for that info, didn't know that,
    i'm no document reading kind of a user :-)
    Bye
  • »10.07.04 - 14:33
    > task on Linux.
    Well you give me the name of a good program
    with a nice GUI that does the job :)
    I agree :-)
  • »10.07.04 - 14:35
    `-target type'
    Well i'm using ffmpeg 0.4.8 on linux, but that version doesn't have the -target option.
    I now downloaded 0.4.6 and 0.4.9-pre1, mabe
    one of these versions has such a option.
    Bye
    Felix.
  • »10.07.04 - 15:21
    Wishmaster
    Try transcode, MythTV and the other programs I don't remember anymore.
    As for ffmpeg, try -vcd
    Pegasos PPC
  • »10.07.04 - 19:30
    > Try transcode, MythTV and the other programs I > don't remember anymore.
    MythTV is new for me, ill check that out.
    Transcode is to much commandline for me.
    I did, i dl a version with the -target option
    as for VCD, no problem, but SVCD doesn't work
    on all DVD players. Realy sux.
    Tnx anyway,
    Gr.
    Felix.
  • »10.07.04 - 21:27
