PegII / Morphos 1.4.2 bug with lowlevel ?
    catohagen
    Posts: 297 from 2003/5/20
    I cant manage to get my psx clone transparent plastic joypad to work with latest MAME.
    I guess i havent runned MAME since i upgraded to
    PegII, but lowlevel.lib by Guido and orginal
    lowlevel doesnt seem to work.
    Im using the gameport on my peg2, and dont tell
    me to buy usb joystick :)
  • »09.07.04 - 18:35
    Posts: 1932 from 2003/10/19
    I was having the same types of problems with the gameport. I ended up just getting a new USB PSX clone pad. I know you didnt want to hear that, but they do work better.
  • »10.07.04 - 13:09
    Toto
    Posts: 268 from 2003/4/20
    I've got no problems with MAME 0.84, my Gravis gamepad pro works fine.
  • »10.07.04 - 13:14
