MPlayer / DVDCSS_METHOD
  • pOS
    pOS
    Posts: 216 from 2003/11/14
    i wasn't able to play DVD Video on my PegII yet.
    I used:
    mplayer -dvd 1 -dvd-device ide.device:3
    I get the error: "icotl: SendChallenge failed"
    Then I had a look into the manual (yes really...). It says, that mplayer uses builtin keys as default. I could force a brute force attack to crack the key by setting environment variable DVDCSS_METHOD to disc.
    So i did:
    setenv DVDCSS_METHOD disc
    But mplayer always tells me:
    "unknown decrypt method. use 'key', 'title' or 'disc' " ???
  • »09.07.04 - 08:26
