Posts: 428 from 2003/8/18
No, no, no and NO !! ;)
MorphOS has so many specific features that you only want to show what you can do on any other OS ?!
Sure you can show that it's possible to watch a Divx, burn a CD,... on MorphOS but I don't think that's what will make people have interest in MorphOS... Don't forget that all people already have a computer with an OS that allows to play divx, burn CD, print,... So I think you should focus on specific MorphOS stuff and on how different it is to do the same things on MorphOS than on "classic" Linux/Win/OSX.
=> Please try to show as many nice specific MorphOS stuff as you can...
For example:
.Multiple screens and how fast you can switch between them,... (different resolutions,...)
.MUI: and how you can have a specific look for any app (and even a different one for different sessions of the same app): just click on the menu->mui settings icon, change something, use/save and here we are !
.USB: you run Mame without a pad plugged... *without* leaving mame, you insert the pad and it works instantly. No need to relaunch the app...
.Plug'n'play video cards ;) First run the Pegasos with a Voodoo... Then power off it, insert a Radeon and... magic, it works ;) no need to install anything or go through XFree86Config... (If you could have access to Radeon (Beta?) 3D driver and show it also works for 3D that would be great but I doubt they would give you even a single byte of new stuff ;()
.A nice Madwizards Demo ;)
.You could also show how easy it is to make a bootable CD: burn your sys: partition and here we are ! ;)
.Show localisation system and how it is integrated into the OS (almost big apps make use of it)
.Show how you can make use of ARexx to communicate between applications
.And to forget to explain that all fits in around 30Mo ! ;)
.... There are so many things to show: why get stuck with DivX and CD Burning ?!
Leo.
[ Edited by Leo on 2004/6/30 17:59 ]
[ Edited by Leo on 2004/6/30 18:02 ]
