crc tool for Morphos?
    weiseb
    Posts: 210 from 2003/3/29
    I am looking for a tool to calculate crc for Morphos
    The problem is that the Amiga tools I found are not able to handle files larger than Ram.
    Of course Morphos native would be great too.
  • »16.01.04 - 20:51
    warface
    Posts: 653 from 2003/2/24
    Right button above the file, then Information.
    There you will find a button called MD5:. Pressing it you will get an MD5 checksum.
    It's integrated in MorphOS :-)
  • »16.01.04 - 21:47
    weiseb
    Yes I know but I realy need crc (too)
    But thanks for helping me to keep the thread on the main page :)
  • »17.01.04 - 18:42
    tokai
    Posts: 1289 from 2003/2/25
    what kind of CRCs you need? :-) I could write you such tool. I have nothing else to do this weekend... just coding around abit and releasing not properly working tools :-P
  • »17.01.04 - 22:11
    weiseb
    Wow that would be great
    I need standard crc32 (used in *.sfv files)
    or like Dirk Stoecker calls it "CRC-32 2"
    Readme
    Tool with sourcecode:
    ftp://de.aminet.net/pub/aminet/dev/c/GetCRC.lha
    The tool is ok but like I said the problem is it
    does not support files larger than ram.
    When you do that I promise to bitch about your webpage colors or the name you give to the programm. :-D
  • »17.01.04 - 23:41
    weiseb
    works well for me.
    thank you very much.
  • »19.01.04 - 17:58
  • Ray
    Ray
    Posts: 21 from 2003/2/24
    Ehh... I posted to the wrong place. :)
    http://amigos.amiga.hu/ray/crctoy.html
  • »20.01.04 - 19:05
  • Targhan
    Posts: 2833 from 2003/2/8
    Common mistake, don't worry about it ;-)
    :idea:Targhan
  • »20.01.04 - 19:09
  • Ray
    Ray
    At last! :) http://amigos.amiga.hu/ray/CRCtoy/CRCtoyMOS
    http://amigos.amiga.hu/ray/CRCtoy/CRCtoy.readme
  • »20.01.04 - 21:34
  • Ray
    Ray
    tokai: Thanks! :) I wrote mine in 1-2 weeks. In my spare time. 68k version is assembler optimized, but not the fastest. :/
  • »21.01.04 - 06:37
