Looking for GFX program
    BigGun
    Posts: 150 from 2004/6/18
    I work as webdeveloper and would like to use MOS as main platform. Unfortunately I don't know which gfx program I can use.
    Can someone please recommand me a gfx program?
    Here is what it need to be able to do:
    -aquire screenshots
    -good resize of pictures
    -increase contrast of picture
    -change hue (to colorize complete pictures)
    -work with transparent images
    -reduce numbers of used colors.
    I often need to create banners or similar stuff as gif.
    So a good color reduction from truecolor
    to 2-256 colors is needed.
    - need to be able to save gifs.
    On Linux I useally use gimp.
    But I really would like to use MOS only if I could find a good gfx program.
    Any Ideas?
    Thanks in advance
    Gunnar
  • »19.06.04 - 15:37
    Posts: 1932 from 2003/10/19
    ImageFX will do all that for you. You can search Aminet for a screen
    grab app. You can find several by jsut typing screen grap in the
    search block.
  • »19.06.04 - 15:51
    BigGun
    Hi Acill,
    But of course I need to be able to paint as well.
    Cut and paste brushes
    and manuall pixeling
    and I need to be able to rotate.
    Can I *paint* or draw in imagefx as well?
    Cheers
    Gunnar
  • »19.06.04 - 15:58
    Wishmaster
    Posts: 342 from 2003/6/29
    Yes, imgex also allows painting.
    Pegasos PPC
  • »19.06.04 - 16:16
