CPU Monitor update for dnetc users available
    Wishmaster
    Posts: 342 from 2003/6/29
    Excellent.
    Pegasos PPC
  • »17.06.04 - 22:27
    AyoS
    Posts: 410 from 2003/8/13
    Thanks,
    A very usefull tool for us Dnet'rs.
    Katos1
  • »18.06.04 - 01:52
    deez
    Posts: 53 from 2003/5/28
    @tokai
    Can you add the new tooltype (DNETCFILTER) to the "statline"?
  • »18.06.04 - 08:07
    DJBase
    Posts: 745 from 2003/4/6
    I would see a transparency mode to the "statline" as feature if possible.
  • »18.06.04 - 10:09
    deez
    @tokai:
    I will be very happy if you add this feature to statline. I'm waiting for new version.
  • »18.06.04 - 14:00
    Bifford
    Posts: 282 from 2003/2/24
    Hiya
    Nice.
    It would be nice if we could set the different settings via a menu as well as tooltypes though.
    And can you do a dual scale - so that the cpu usage WITHOUT dnet shows up in green, and then in a semi-transparent colour behind that scale is shown the full cpu with dnet included???? thanks!
    Bifford.
    Bifford the Youngest
  • »18.06.04 - 15:37
    tokai
    Posts: 1289 from 2003/2/25
    @djbase:
    that's sadly nearly impossible. at least not in a clean way. Atm. there is only one solution that's to use the "crop some part of ambient background and use it for statline background" trick. I would add it when it could be added in a clean way.. we have to wait for real alpha layers.
    @deez:
    it is already on the list. :-)
    @bifford:
    I agree. Actually it's planned to have all settings of cpumonitor inside a own prefswindows. Tooltypes are just a substitute solution for now. Also the semi-transparent scale was already planed. I just had no time to modify the draw routine, but wanted to release that version to support dnetc (I dissabled dnetc actually, so CPU Monitor looked properly ;-) )
    regards,
    tokai
  • »18.06.04 - 20:20
    Bifford
    I'm guessing that you use the figures thrown out by Task Manager - take the overall cpu usage minus the dnet usage (96.70% atm) and plot the result.
    Or is there some other way you have done it? (without disabling dnet ;-)
    Biff
  • »19.06.04 - 04:46
