Wierd Net problems
    Posts: 1932 from 2003/10/19
    I keep getting these wierd net problems. My system goes online fine in MiamiDX but its been droping off or something. I get the error "net error" in Voyager and something like host lookup failed, no DNS foind in Ibrowse. If I reboot its okay again, but starts up soon after. Any ideas? I am using the Via Rhine port. and Miami is registered. Could my keys be corrupt?
  • »17.06.04 - 01:45
    DJBase
    Posts: 745 from 2003/4/6
    Hm, have you tried to change the DNS Server?
  • »17.06.04 - 04:11
    Spidey
    Posts: 568 from 2003/2/24
    Hi Acill,
    Did your network connection work before this problem or are you trying a new network connection?
    Do you have the relevant IP-adresses from your provider (DNS, your own, Gateway. Oh and the subnetmask)? In that case you could fill in all data manually.
    Bye,
    Spidey
  • »17.06.04 - 04:38
    I havent done anythig new. Its the same settings I've used since I
    installed miamiDX and used Miami Init to get its settings. I used my
    keys from my backup CD and all seems okay now. Not sure if that was
    it, and how the would go bad if it was.
  • »17.06.04 - 09:25
  • o1i
    Posts: 50 from 2003/2/25
    Hmm, maybe it was not a problem with your
    settings, but:
    "Akamai DNS Outage Messes up Net" ?
    For more info see:
    http://slashdot.org/article.pl?sid=04/06/15/1427213&mode=thread&tid=126&tid=95
  • »17.06.04 - 10:53
