MOL----Install Question?
    Posts: 81 from 2004/3/20
    I posted this on the linuxppc site as well as I don't know where I can get an answer. I have MOL installed on my 2.4.25-2 kernel debian system. Whenever I startmol from the command prompt with an OS X ver10.3.2 disc (disc 1) in the drive, I get a repetative error that the drive is busy. The only thing I can list on that cd from linux is the word CDROM 1, which it is. Has anyone done an install with this version of the OS? If so, how? I know it's supported as the website claims so. Sorry for the linux post over here, but the more publicity, the more I might get a clue on solving the problem.
    Regards,
    Harry
    Config: Pegasos II G4 1ghz, 1024mb memory,
    Radeon 9200,160gb hd total, Sound Blaster Live!
  • »12.06.04 - 16:01
    Posts: 236 from 2003/7/28
    I never got MOL to work with PegXLin after i updated to kernel 2.4.25.
    I just use the PegXmac CD (which I have subsequently copied to hard disk) to launch MOL, and it works fine on my PEG-1. I have OS X 10.3.4 installed and the only thing I don't have working (yet) is sound. I have a SB Live! card.
  • »13.06.04 - 01:50
    The PegXLin disc, is, I gather, the install disc from the X OS set? I am not familiar with this if it isn't. Could you explain?
    Thanks a ton!!!
    Harry
  • »13.06.04 - 02:55
    BTW.....the install disc acts like an HFS volume, only I can't mount it as one. The only thing readable with it mounted as ISO-9660 is the disc title.
    Harry
  • »13.06.04 - 02:56
    Google pegXmac and you'll find where to get it.
  • »13.06.04 - 04:16
    I've got the pegXlin burned, however this disc seems like a full install system for Linux? I have Debian 2.4.25-2 installed, my problem is getting Mac OS X 3.2 transferred to the drive I have set up for Mac OS. Will this disc automate that?
    Harry
  • »13.06.04 - 11:23
    Google pegXmac
    Got it, thanks.
    Harry
  • »14.06.04 - 02:43
