Voyager Fonts
    Posts: 1932 from 2003/10/19
    I've downloaded the 68k version of Voyager to see how it works on my
    Pegasos. I like the bookmarks, but the one thing it does that my
    MorphOS version does not seem to do is proper font management. If I go
    to a font test page it will show all the fonts as they are called
    since I installed the core fonts into my fonts dir. The MorphOS
    version just displays my default fonts as I chose them. How can I get
    the newer voyager inclused in MorphOS to do this?
  • »12.06.04 - 00:41
    DoctorMorbius_FP
    Posts: 315 from 2004/2/13
    If you have installed or will install the truetype webfonts described in my review, I can send you my configuration files for Voyager 68k and Voyager MOS.
    Well, if this could help people, I can make them publicly available...
    Regards
  • »13.06.04 - 11:27
    cecilia
    Posts: 459 from 2003/8/30
    maybe this might help. i read this when i was setting fonts up on my amiga.http://www.kittycat.co.uk/computing/webfonts/
  • »13.06.04 - 13:15
    Brumiga
    Posts: 276 from 2004/4/3
    hello,
    @Cecilia, i do not think that the indications given on your link are for Morphos. they use the programs inside ttflibrary archive to create bitmap fonts from the truetype fonts on amiga. and i do not know/understand why not using directly truetype fonts ? are not those ones inside mossys:fonts_ttf enough or correct ? it is possible to complete them with some of those one they recommend on download from sourceforge.
    Brumiga
  • »13.06.04 - 14:28
    cecilia
    the link goes directly to the section on setting up Voyager. (it's about halfway down the page) I know MOS has it's own TT font engine.
    it lists fonts that are standard for most web pages and will make your web browsing better.
    Andale Mono
    Arial
    Arial Black
    Arial Narrow
    Comic Sans MS
    Courier New
    Georgia
    Impact
    Lucida
    Tahoma
    Times New Roman
    Trebuchet MS
    Verdana
    Webdings & Wingdings
  • »13.06.04 - 22:17
