cant login on Morphone with Voyager.
    serge
    Posts: 725 from 2003/2/20
    I cant login with voyager on MorphZone.
    Works fine with Ibrowse.
    Is it possible to use Voyager?
  • »31.05.04 - 23:03
    Paochi
    Posts: 136 from 2004/3/23
    Simply, after you inserted L & P, click on the RELOAD page button and all will work nice
    "I hope that all my toys are, first of all, funny!" (Jay Miner)
  • »31.05.04 - 23:11
    serge
    it works. Thank you very much
  • »31.05.04 - 23:19
  • jah
    jah
    Posts: 69 from 2003/3/24
    @admins
    why not adding something to the end of the url once logged
    like ?<date> or ?<nick>
    this way the url is "different" and the browser will truely reload the
    page instead of looking into the cache
  • »01.06.04 - 03:10
  • Targhan
    Posts: 2833 from 2003/2/8
    Just set the cache size to zero. Voyager's cache will be repaired someday(tm), besides I think it is important to have that particular error on THIS site.
    If Serge tried to login at a simular site with Voyager, he might just assume that the site was broken or his account was deleted--never realizing that there *is* a caching problem. At least here, the problem is identified. (It's in the FAQ, with window-grabs even!)
    :idea:Targhan
  • »01.06.04 - 07:24
    Paochi
    Yep Thargan :-D
    Fix a page just for our bugged browser is not an help and ... the problem should be solved in the next Mos1.5 release: it should contain a new Voyager too, right?
    PS
    What are the new feature-fixes that are planned in next Voyager release? (if Zapek can answer here...)
  • »01.06.04 - 08:38
