SFS: filesize 4GB limit?
    Spidey
    Posts: 568 from 2003/2/24
    Hi everybody,
    Has SFS a 4GB filesize limit?
    Atleast I could't copy a file of 4.3GB to my harddrive (I got a negative remaining HD space during the copy-process :-)).
    Is it possible to have >4GB files with the Peg?
    Thanks,
    Spidey
  • »27.05.04 - 05:01
    Posts: 1932 from 2003/10/19
    Well thats not good! What if you want to make some DVD-R movies or data when the time comes that MOS can support that?
  • »27.05.04 - 09:25
    MacFly
    Posts: 37 from 2003/10/14
    dont worry , Burnit is already able to handle such files.
  • »27.05.04 - 10:25
    Posts: 1087 from 2003/3/24
    Will BurnIT Support Dual Layer DVDs?
  • »27.05.04 - 11:02
    It should read them, but nothing writes to them ATM.
  • »27.05.04 - 12:03
    Paochi
    Posts: 136 from 2004/3/23
    The problems is not SFS, but all old programs (68k mainly).
    Anyway both DVD-R morphos future software support filesize bigger then 4GB.
    "I hope that all my toys are, first of all, funny!" (Jay Miner)
  • »27.05.04 - 12:18
    Chain-Q
    Posts: 350 from 2003/10/12
    And what about the well-known ~2GB filesize limit in dos.library? Or does MorphOS have some new API available in its dos.library (eg. parts of QBox API?) for DVD-R software developers which allow to work around this problem?
    [.Hosting AmigaSpirit.hu.]
  • »27.05.04 - 12:39
    Schlonz
    Posts: 131 from 2004/4/16
    AFAIK this annoying 2GB file limit is in the MOS dos.library, too.
    I think that both BurnIT 3 and FryingPan will handle this problem by splittig the DVD image files into chunks of less than 2 GB of size.
    dvdrecord would be able to burn DVDs which contain more than 2 GB if there wouldnt be this 2 GB file size problem of dos.library, but currently I am not really motivated to change this in dvdrecord as BurnIT 3 will appear soon.
  • »27.05.04 - 14:39
    Posts: 12 from 2003/8/7
    Hello,
    i think, there is one problem more.
    When i'll playing some MEPG-videos from
    DVD-R media, the Mplayer has a problem with
    files, there sectors was saved over 4GB!
    With other words, Mplayer played files till 4096MB correctly and suddenly the first file (data-sector 0)
    was played. This problem is with all my DVD-R medias (written with PC).
    A copy back to HDD has the some problem!
    Hey, any ideas???
    (used on Peg1/April1 and DVD-ROM+CD-RW combo from Philips and MOS 1.4)
  • »28.05.04 - 05:28
    Neko
    Posts: 301 from 2003/2/24
    SFS has no such limitation, but dos.library does. There are some extensions planned for 64bit file access which will solve this *for apps that utilise them*.
    As for having "negative remaining HD space", I suspect that's a cosmetic bug regarding the tools that calculate the remaining HD space.
    Neko
    Matt Sealey, Genesi USA, Inc.
    Developer Relations
    Product Development Analyst
  • »28.05.04 - 06:22
    Spidey
    Hello Neko (and all other replyers :-)),
    Well, that cosmetic negative HD space I got from DirOpus, but:
    I was copying that file (4.3GB size) from my pc to my PegII (network with Samba). So, I never used an Amiga-prog to copy it.
    When the error occured I looked at DirOpus and saw that negative figure.
    I checked SFS documentation (from the internet) and read the biggest supported filesize was just below the 4GB.
    If I have it right, we'll get an update that will solve this "problem"? Nice! :-D
    (I dare not to ask "when", I'm just glad the problem is being taken care of ;-))
    Bye,
    Spidey
  • »28.05.04 - 11:40
    MarK
    Posts: 641 from 2004/1/25
    FryingPan supports ISO-on-the-fly, so don't worry about the file sizes. And iirc, all the DVDs has it's movie files separated to 1 gig chunks, so there is no file bigger, than 2 gigs at all.
    Bye, MarK.
  • »28.05.04 - 13:47
    ironfist
    Posts: 254 from 2004/4/22
    That is correct - I have never seen any vob-files larger than 1024MB.
  • »28.05.04 - 18:36
    GK_LKA
    Posts: 481 from 2004/3/28
    Well, it's OK, that the files on the DVD are splitted into 1GB parts, but what happens if you have a DVD ISO image? It's 4.7 GB in size!
    [ GK / LKA Team ]
  • »28.05.04 - 18:59
    Chain-Q
    You'll probably say some bad words... :-D
  • »28.05.04 - 22:44
    Neko
    DOpus will give you freaky figures.. please don't expect this is a bug in MorphOS.
    Developer Relations
  • »31.05.04 - 13:33
    Schlonz
    >by GK_LKA on 2004/5/28 22:59:39
    Yeah, you are right.
    To be able to burn that kind of DVDs there would be two solutions:
    1. burn DVDs from a given path containing all the data on-the-fly without creating a ISO image first
    2. create a ISO image which is splitted in chunks of less than 2 GB size; these chunks will have to be put together again by the burning application.
  • »31.05.04 - 20:27
