Telegram Amiga GUI alpha 0.0.1 for MorphOS released
    kaffeine2
    Posts: 16 from 2019/3/31
    Hi all,
    I have released the first public MorphOS alpha of Telegram Amiga.
    Telegram Amiga is a from-scratch native Telegram client for Amiga-like systems. The important part is that this is the real MTProto user-client path, not the Telegram Bot API and not a web wrapper. It logs in as a Telegram user account, creates/reuses a local auth session, reads chats/history and sends text messages.
    The MorphOS package is here:
    https://github.com/kaffeine1/telegram-amiga/releases/tag/morphos-alpha-0.0.1
    General release page:
    I also wrote a release note with screenshots here:
    https://androidlab.it/telegram-amiga-gui-alpha-001-amigaos-morphos-aros/
    This alpha includes two clients built on the same engine:
    - TelegramGUI: native Intuition/GadTools GUI with chat list, conversation view and text sending;
    - TelegramTUI: text-mode / console client.
    The MorphOS build is PowerPC native and is intentionally dependency-light:
    - no MUI requirement;
    - no ixemul requirement;
    - no AmiSSL requirement;
    - built-in MTProto crypto path: RSA, Diffie-Hellman, SRP/2FA, AES and SHA code are in the project;
    - uses the MorphOS TCP/IP stack through bsdsocket.library.
    The GUI alpha currently focuses on the basic text-chat workflow:
    - first login from the client: phone number, Telegram code, optional 2FA password;
    - local session reuse after login;
    - chat list;
    - conversation view;
    - sending text messages;
    - live send/receive loop;
    - "is typing" indicator;
    - read receipts;
    - scrollbars / mouse wheel / keyboard navigation;
    - remembered window size.
    This release is still alpha software, so rough edges are expected. Everyday direct-message and group text use works in the current test path, but I would still treat it as a test build and not as a polished desktop client yet.
    One MorphOS-specific issue that blocked the GUI for a while was a deep startup/shutdown freeze related to socket/library lifetime. The current build owns bsdsocket.library explicitly and closes it in-process instead of leaving the teardown to libnix exit handling; that fixed the system-freeze I was seeing after closing the GUI on MorphOS.
    Useful feedback would be:
    - MorphOS version;
    - machine model: Mac mini G4, PowerBook, PowerMac, Pegasos, Efika, QEMU, etc.;
    - network setup / TCP-IP stack details if relevant;
    - whether TelegramGUI starts cleanly;
    - whether login works;
    - whether chat list, history, sending and receiving work;
    - freezes, crashes, requester messages, visual glitches or strange delays.
    Important privacy note: please do not post auth files, phone numbers, Telegram login codes, 2FA passwords, access hashes or private message text. Redacted screenshots and logs are perfect.
    The archive includes Manual-EN.txt and Manuale-IT.txt.
    Thanks for any MorphOS testing and feedback.
  • »20.06.26 - 10:38
    tolkien
    Posts: 576 from 2013/5/29
    First of all, thanks for the efford. Woud be nice to have a telegram client.
    With the previous version I can log and chat but was inestable. Sometimes freeze the computer.
    This last version is more inestable to me.
    The GUI version freeze the computer at the start.
    With the TUI version I have a bit more lucky and sometimes works.
    Cant send a more complete report because of the computer freeze.
    But sometimes the TUI version show this in the logtool:
    83.545| >>> Exception 4 <Illegal Inst Access at ff004a98>
    83.545| ----------------------------------------------------------------------
    83.545| Quark Thread TID 0000000010020010 Name ABox
    83.545| SRR0 0xff004a98 SRR1 0x4200f030
    83.545| LR 0xff004a98 CTR 0x000349b0
    83.545| CR 0x28204244 XER 0x20000400
    83.545| GPR[00] ff004a98 1e08d180 1e0a0d90 00000080 00000001 008b8020 00000001 00000000
    83.545| GPR[08] 1e0a0d90 00000000 14001a38 0200f030 01d0ea00 00000000 00000002 15be0000
    83.545| GPR[16] 00000000 1e08d1b8 15bf0000 1e08d1bc 00000000 00000000 1e08d248 00000000
    83.545| GPR[24] 15bf0000 00001080 00000000 01ffffff 05cccc99 00000000 71c2bbb4 ffd7c6b3
    83.545| FPSCR 82020000
    83.545| FPR[00] 0000001400000000 0000000000000000 040001bb00000000 0000000050000000
    83.545| FPR[04] fff80000000080e8 fff8000000007530 3fe3333320000000 3fd4031ce0000000
    83.545| FPR[08] 3fd50e2c20000000 3fe3333340000000 41e0000000000000 4330000000000000
    83.545| FPR[12] 410c6db0193fdf99 40112d003959203f 0000000000000000 0000000000000000
    83.545| FPR[16] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    83.545| FPR[20] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    83.545| FPR[24] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    83.545| FPR[28] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    83.545| VSAVE 00000000 VSCR 00010000
    83.545| VPR[00] 00000000000000000000000000000000 00000000000000000000000000000000
    83.545| VPR[02] 00000000000000000000000000000000 00000000000000000000000000000000
    83.545| VPR[04] 00000000000000000000000000000000 00000000000000000000000000000000
    83.545| VPR[06] 00000000000000000000000000000000 00000000000000000000000000000000
    83.545| VPR[08] 00000000000000000000000000000000 00000000000000000000000000000000
    83.545| VPR[10] 00000000000000000000000000000000 00000000000000000000000000000000
    83.545| VPR[12] 00000000000000000000000000000000 00000000000000000000000000000000
    83.545| VPR[14] 00000000000000000000000000000000 00000000000000000000000000000000
    83.545| VPR[16] 00000000000000000000000000000000 00000000000000000000000000000000
    83.545| VPR[18] 00000000000000000000000000000000 00000000000000000000000000000000
    83.545| VPR[20] 00000000000000000000000000000000 00000000000000000000000000000000
    83.545| VPR[22] 00000000000000000000000000000000 00000000000000000000000000000000
    83.545| VPR[24] 00000000000000000000000000000000 00000000000000000000000000000000
    83.545| VPR[26] 00000000000000000000000000000000 00000000000000000000000000000000
    83.545| VPR[28] 00000000000000000000000000000000 00000000000000000000000000000000
    83.545| VPR[30] 00000000000000000000000000000000 00000000000000000000000000000000
    83.545| IABR 00000000
    83.545| DABR 00000000
    83.545| MMCR0 00000000
    83.545| MMCR1 00000000
    83.545| MMCR2 00000000
    83.545| PMC1 00000000 PMC2 00000000 PMC3 00000000 PMC4 00000000
    83.545| SIA 00000000
    83.545| SDA 00000000
    83.545| >>> Quark Thread Stack History
    83.545| >>> ABox State
    83.546| ExecBase: SysBase 0x14001a38
    83.546| SysFlags 0x0000 AttnResched 0x0000 IDNestCnt -1 TDNestCnt -1
    83.546| ThisTask 0x1e027f10 TaskReady 0x14001bd2 TaskWait 0x14010070
    83.546| ResModules 0x14004398
    83.546| TaskTrapCode 0x1012ae68 TaskExceptCode 0x1012ae60 TaskExitCode 0x1012ae7c
    83.546| TaskSigAlloc 0xf1ff TaskTrapAlloc 0x8000
    83.546| IdleCount 20483 DispCount 277390
    83.546| Quantum 4 Elapsed 4
    83.546| VBlankFrequency 50 PowerSupplyFrequency 50 EClockFrequency 709379
    83.546| MainTID 0x10020010 SchedulerTID 0x10020012 SchedulerSig 0x80000000
    83.546| OldSRR0 0x0
    83.546| ConfigServerTID 0x10000013
    83.546| LastIntObject 0x15b99494
    83.546| LastIntObject 0x15b99494 <Not Valid ptr>
    83.546| Code 0x15d8eadc Data 0x15be2e94
    83.546| Int0: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    83.546| Int1: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    83.546| Int2: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    83.546| Int3: iv_Code 0x101315ce iv_Data 0x14004868 iv_Node 0x00000000
    83.546| Int4: iv_Code 0x101315ce iv_Data 0x14004888 iv_Node 0x00000000
    83.546| Int5: iv_Code 0x101315ce iv_Data 0x14004878 iv_Node 0x00000000
    83.546| Interrupt 0x14040dd6 <graphics.library>
    83.546| Code 0x101a0108 Data 0x14040d8c
    83.546| Interrupt 0x1590e0f8 <ixemul timer interrupt>
    83.546| Code 0x1590ab94 Data 0x00000000
    83.546| Int6: iv_Code 0x101a0110 iv_Data 0x14040d8c iv_Node 0x14040e02
    83.546| Int7: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    83.546| Int8: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    83.546| Int9: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    83.546| Int10: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    83.546| Int11: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    83.546| Int12: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    83.546| Int13: iv_Code 0x101315ce iv_Data 0x14004898 iv_Node 0x00000000
    83.546| Int14: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    83.546| Int15: iv_Code 0x101315ce iv_Data 0x140048a8 iv_Node 0x00000000
    83.546|
    83.546| >>> Running Task
    83.546| ----------------------------------------------------------------------
    83.546| Task 0x1e027f10 Name 0x1e028c74 <Background CLI> Type 13 Pri 0
    83.546| Flags 0x8 State 2 IDNestCnt -1 TDNestCnt -1
    83.546| SigAlloc 0x8000f1ff SigWait 0x00001080 SigRecvd 0x00000100 SigExcept 0x00000000
    83.546| ExceptCode 0x1012ae60 ExceptData 0x00000000 TrapCode 0x1012ae68 TrapData 0x00000000
    83.546| Switch 0x00000000 Launch 0x00000000 UserData 0x00000000
    83.546| SPLower 0x1cc93824 SPUpper 0x1ccd3824 SPReg 0x1ccd37bc
    83.546| ETask 0x1dff0194
    83.546| MemPool 0x14ef1300 PPCLibData 0x00000000
    83.546| PPCSPLower 0x1e098e84 PPCSPUpper 0x1e0a0e80
    83.546| PPCTrapMsgPort 0x00000000 PPCTrapMessage 0x15a2c7a4
    83.546| PPCRegFrame 0x1e0a09a0
    83.546| Private[] 0x00000000 0x00000000 0x00000000 0x00000000
    83.546| EmulHandle 0x00000000
    83.546| EmulHandle 0x1e0a0d90 Type 0x00000004 Flags 0x00000001
    83.546| SuperHandle 0x10001000 Type 0x00000000 WaitMask 0x00000000 SyncMask 0x00000000
    83.546| USP 0x00000000 SSP 0x14003a30 VBR 0x1400ef30
    83.546| SFC 0x00000000 DFC 0x00000000 CACR 0xa0808000 TC 0x00000000
    83.546| ITT0 0x00000000 ITT1 0x00000000 DTT0 0x00000000 DTT1 0x00000000
    83.546| URP 0x00000000 SRP 0x00000000 BUSCR 0x00000000 PCR 0x04310501
    83.546| >>> Task Registers Frame
    83.546| SRR0 0xff004a98 SRR1 0x4200f030
    83.546| LR 0xff004a98 CTR 0x000349b0
    83.546| CR 0x28204244 XER 0x20000400
    83.547| GPR[00] ff004a98 1e08d180 1e0a0d90 00000080 00000001 008b8020 00000001 00000000
    83.547| GPR[08] 1e0a0d90 00000000 14001a38 0200f030 01d0ea00 00000000 00000002 15be0000
    83.547| GPR[16] 00000000 1e08d1b8 15bf0000 1e08d1bc 00000000 00000000 1e08d248 00000000
    83.547| GPR[24] 15bf0000 00001080 00000000 01ffffff 05cccc99 00000000 71c2bbb4 ffd7c6b3
    83.547| FPSCR 82020000
    83.547| FPR[00] 0000001400000000 0000000000000000 040001bb00000000 0000000050000000
    83.547| FPR[04] fff80000000080e8 fff8000000007530 3fe3333320000000 3fd4031ce0000000
    83.547| FPR[08] 3fd50e2c20000000 3fe3333340000000 41e0000000000000 4330000000000000
    83.547| FPR[12] 410c6db0193fdf99 40112d003959203f 0000000000000000 0000000000000000
    83.547| FPR[16] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    83.547| FPR[20] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    83.547| FPR[24] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    83.547| FPR[28] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    83.547| VSAVE 00000000 VSCR 00010000
    83.547| VPR[00] 38333534360000080000000178300000 008b0307000000000000000000000000
    83.547| VPR[02] 008b0307303031300000000100000000 1c1c1c1c000000200000000100000000
    83.547| VPR[04] 1c1c1c1c0000002d00000000a5fdbbf0 1000d990000452dc00000000a5fdbbf0
    83.547| VPR[06] 00000000000000000000000a008b1378 008b0310433000004054e2f300635007
    83.547| VPR[08] 00000000000000000000000000000000 00000000000000000000000000000000
    83.547| VPR[10] 00000000000000000000000000000000 00000000000000000000000000000000
    83.547| VPR[12] 1000d970ffffffff1000d9f00000000a 1000d9801000d9981e1e1e1e0000000a
    83.547| VPR[14] 1000d990000118ac1000d8f800000000 1000d9c00004541400000000a5fdbbf0
    83.547| VPR[16] 18181818000000004330000001fca055 1000d9c0000000001e1e1e1e00000000
    83.547| VPR[18] 1000d9d000045480000000001000dad0 1000da50000465000000000178300000
    83.547| VPR[20] 00000000000000000000000000000000 30003000343861380000000000000000
    83.547| VPR[22] 00000000000000000000000000000000 1135adcc000000000000000000000000
    83.547| VPR[24] 11359078000000001a1a1a1a1b1b1b1b 1c1c1c1c1d1d1d1d1a1a1a1a1b1b1b1b
    83.547| VPR[26] 1c1c1c1c1d1d1d1d1e1e1e1e1f1f1f1f 1000daf0000451040000000000000000
    83.547| VPR[28] 0000000100bcb0080000000a000015eb 11359a5700bcc5fa0000000000000000
    83.547| VPR[30] 00000000000000000000000000000000 00000000000000000000000000000000
    83.547| >>> Task Stack History
    83.547| ----------------------------------------------------------------------
    83.547| ***PPC Stack Ptr is not between PPCSPLower and PPCSPUpper
    83.547| Stack: 0x1e08d180
    83.547| 0x1e08d160[-0x20] f4decfbe 1a585862 00000000 01ffffff
    83.547| 0x1e08d170[-0x10] 05cccc99 00000000 71c2bbb4 ffd7c6b3
    83.547| 0x1e08d180[0x000] fb0c243d ff004a98 ff025eab ff0472c1
    83.547| 0x1e08d190[0x010] ff0077ce ff4d5980 fff92d18 ffe40400
    83.547| >>> Full PPC mode: Last saved 68k context
    83.547| PC 87654321 SR 0008
    83.547| Dn[0] 00001080 00000000 00000000 00000001 1c7e46a0 1e08d060 1cc13358 1c78a2f8
    83.547| An[0] 15beae0c 00000000 00000000 1e08d278 00000000 00000001 14001a38 1ccd381c
    83.547| Stack: 0x1ccd381c
    83.547| 0x1ccd37fc[-0x20] 2b3f082c 41082e42 092f430a 2f430a2e
    83.547| 0x1ccd380c[-0x10] 430a2e42 0a2c400a 2a3d0827 11362610
    83.547| 0x1ccd381c[0x000] 00040000 1e028c70 34042a3b 1cc93808
    83.547| 0x1ccd382c[0x010] 0072ae49 140000b8 140000b8 27380624
    83.547| 0x1ccd383c[0x020] 35062030 061c2b05 1e2c031e 2c031e2c
    83.547| 0x1ccd384c[0x030] 03202d03 24350326 37032839 052a3d06
    83.547| 0x1ccd385c[0x040] 2d400730 44083148 09324a09 334c0933
    83.547| 0x1ccd386c[0x050] 4b0a334c 0a334c0b 334c0634 4b073049
    83.547| 0x1ccd387c[0x060] 072d4506 2c42062a 3e062334 041d2c03
    83.547| 0x1ccd388c[0x070] 1f2d0321 2d032331 03233303 23340322
    83.548| >>> Last saved PPCThread State
    83.548| ----------------------------------------------------------------------
    83.548| SRR0 0x1012428c SRR1 0x0200f030
    83.548| LR 0x10110b60 CTR 0x00023d20
    83.548| CR 0x88204884 XER 0x20000400
    83.548| GPR[00] 0002131c 1e08d160 1e0a0d90 00000001 008b6e8c 008b8020 00000001 00000000
    83.548| GPR[08] 1e0a0d90 01d0e550 00000008 00000000 00008000 00000000 00000002 15be0000
    83.548| GPR[16] 00000000 1e08d1b8 15bf0000 1e08d1bc 00000000 00000000 1e08d248 00000000
    83.548| GPR[24] 15bf0000 00001080 14001be0 00000004 ffffffff 0000ff00 1e027f10 14001a38
    83.548| FPSCR 82020000
    83.548| FPR[00] 0000001400000000 0000000000000000 040001bb00000000 0000000050000000
    83.548| FPR[04] fff80000000080e8 fff8000000007530 3fe3333320000000 3fd4031ce0000000
    83.548| FPR[08] 3fd50e2c20000000 3fe3333340000000 41e0000000000000 4330000000000000
    83.548| FPR[12] 410c6db0193fdf99 40112d003959203f 0000000000000000 0000000000000000
    83.548| FPR[16] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    83.548| FPR[20] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    83.548| FPR[24] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    83.548| FPR[28] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    83.548| VSAVE 00000000 VSCR 00010000
    83.548| VPR[00] 00000000000000000000000000000000 00000000000000000000000000000000
    83.548| VPR[02] 00000000000000000000000000000000 00000000000000000000000000000000
    83.548| VPR[04] 00000000000000000000000000000000 00000000000000000000000000000000
    83.548| VPR[06] 00000000000000000000000000000000 00000000000000000000000000000000
    83.548| VPR[08] 00000000000000000000000000000000 00000000000000000000000000000000
    83.548| VPR[10] 00000000000000000000000000000000 00000000000000000000000000000000
    83.548| VPR[12] 00000000000000000000000000000000 00000000000000000000000000000000
    83.548| VPR[14] 00000000000000000000000000000000 00000000000000000000000000000000
    83.548| VPR[16] 00000000000000000000000000000000 00000000000000000000000000000000
    83.548| VPR[18] 00000000000000000000000000000000 00000000000000000000000000000000
    83.548| VPR[20] 00000000000000000000000000000000 00000000000000000000000000000000
    83.548| VPR[22] 00000000000000000000000000000000 00000000000000000000000000000000
    83.548| VPR[24] 00000000000000000000000000000000 00000000000000000000000000000000
    83.548| VPR[26] 00000000000000000000000000000000 00000000000000000000000000000000
    83.548| VPR[28] 00000000000000000000000000000000 00000000000000000000000000000000
    83.548| VPR[30] 00000000000000000000000000000000 00000000000000000000000000000000
    83.548| ***PPC Stack Ptr is not between PPCSPLower and PPCSPUpper
    83.548| SRR0[0x1012428c] -> exec_of_604e.elf [Hunk 0 Offset 0x0002428c]
    83.548| LR[0x10110b60] -> exec_of_604e.elf [Hunk 0 Offset 0x00010b60 Function Wait]
    83.548|
    83.548| SegList 0x0569511c GlobVec 0x14035a70
    83.548| StackBase 0x07324e09 StackSize 0x00040000
    83.548| TaskNum 0x00000001 Result2 0x00000000
    83.548| CurrentDir 0x071efe72 CIS 0x071f5b27
    83.548| COS 0x0780603f CES 0x07812803
    83.548| ConsoleTask 0x1e05ec90 FileSystemTask 0x140645b4
    83.548| CLI 0x071efc0f ReturnAddr 0x1ccd381c
    83.548| PktWait 0x00000000 WindowPtr 0x00000000
    83.548| HomeDir 0x071ef68a Flags 0x00000044
    83.548| ExitCode 0x00000000 ExitData 0x00000000
    83.548| Arguments 0x1e01ebfc ShellPrivate 0x00000000
    83.548| CmdName: <telegram-test>
    83.549| >>> End of Exception State Dump
    83.549| ----------------------------------------------------------------------
    I have tried it with a Powerbook g4 and a powermac g5. Both with MorphOS 3.20.
    If you need a more specific test let me now.
  • »21.06.26 - 06:24
    tolkien
    Anyway...could be a stack issue?
    You add stack in the launch script but IIRC that stack is for 68k applications.
    You need to add the ppc stack in your code.
    Using maxstack I see a "Background CLI" task (Telegram one) using 32756 of 32756 bytes ppc stack used.
    Well, I have no idea but Hope It could help to trace the problem.
    Edit:
    I see in your code
    unsigned long __stack = 1048576UL;
    soI guess it is ok.
    [ Editado por tolkien 21.06.2026 - 08:41 ]
  • »21.06.26 - 07:12
    kaffeine2
    Hi, and thank you seriously.
    You were right: this was a PPC stack issue. The launcher Stack command only affects the 68k side, while the PPC ELF was still using the default ~32 KB PPC task stack.
    Your maxstack result, 32756 / 32756, plus the PPC Stack Ptr is not between PPCSPLower and PPCSPUpper exception, pointed straight at the cause. The crypto handshake and GUI text wrapping were overflowing that tiny stack, and the recent changes made it easier to trigger.
    The fix is now in code: the MorphOS build requests a 1 MB PPC stack via __stack, so libnix should switch to it before main(). maxstack should now show about 1 MB instead of ~32 KB.
    It did not crash on my PowerMac G5 because my account/usage apparently stayed just below the limit, so I was chasing the wrong lead. Your report caught the real issue.
    The corrected build is already online in the same release:
    https://github.com/kaffeine1/telegram-amiga/releases/tag/os3-alpha-0.0.1
    Please re-download the MorphOS archive and test both GUI and TUI on your PowerBook G4 and PowerMac G5. Any feedback on how they behave would be very useful.
    Thanks again for testing and digging into it. This is exactly the kind of feedback that makes the client better.
  • »21.06.26 - 07:40
    tolkien
    Damn...afrer a local recompile with 3.20 sdk now it works nicely! Even the gui version!
  • »21.06.26 - 07:52
    kaffeine2
    Great, that is very good news, thank you for testing it again.
    So the PPC stack fix was definitely needed, and it is interesting that a local rebuild with the MorphOS 3.20 SDK works nicely on your side too, including the GUI.
    Your feedback was really useful in tracking this down.
    Thanks again for the help.
  • »21.06.26 - 08:09
    kaffeine2
    One last check, if you don't mind: could you also try the binary from the release (MorphOS alpha 0.0.1, re-download the archive) rather than your local recompile?
    If the released binary works too, we know it's fixed for everyone; if only your local recompile works, then it's an SDK difference (my cross-compiler vs your native 3.20 SDK) and I'll dig into that
    [ Edited by kaffeine2 21.06.2026 - 11:07 ]
  • »21.06.26 - 09:32
    tolkien
    Yes..I tried your binary from GitHub and works nicely.
    Great work!
    [ Editado por tolkien 21.06.2026 - 12:16 ]
  • »21.06.26 - 11:10
    kaffeine2
    The new Telegram Amiga alpha 0.0.3 release is now available.
    This version adds native replies in the GUI, Telegram-style checkmarks, faster refresh, double buffering to reduce flickering, a button to jump back to the latest message, and cleaner packages for the supported Amiga-like platforms.
    Article with details and screenshots:
    https://androidlab.it/en/telegram-amiga-alpha-003-replies-checkmarks-amigaos-morphos-aros/
    The release/download links are inside the article, just scroll down a little.
    As always, testing on real hardware or emulators is very welcome, as are bug reports, feedback, suggestions and problem reports.
    [ Edited by kaffeine2 27.06.2026 - 06:25 ]
  • »27.06.26 - 06:23
    tolkien
    Have done a quick test and seems It works nicely.
    Reply feature rocks.
    Thanks for the support.
  • »27.06.26 - 11:45
    kaffeine2
    Thanks to you for always testing and giving feedback.
  • »27.06.26 - 12:08
    kaffeine2
    I have released the new version of Telegram Amiga, 0.0.5.
    This release brings several improvements: real avatars in the chat list, @ mention autocomplete in groups, optional own-screen mode (for now it requires manual configuration: in the Telegram Amiga drawer, edit data/telegram-gui-win.txt; the line must use the format width height x y own), remembered window position and size between sessions, a fix for the right-click freeze, cleaner handling of data/ and avatars/, and better preservation of newlines and lists in messages.
    Full article with details and links to the GitHub/Aminet packages:
    https://androidlab.it/en/telegram-amiga-alpha-005-avatars-mentions-own-screen-amigaos-morphos-aros/
    As always, testing on real hardware or emulated setups is extremely valuable: bug reports, freezes, graphical issues, incompatibilities or any odd behaviour are very welcome. The more platforms and configurations we test, the more solid the client becomes.
  • »07.07.26 - 17:57
    tolkien
    Its so great to have Telegram in our machines.
    Im usign the os3 and morphos versión almost daily.
    To makes It near perfect is to have a proper MUI gui instead of a "custom" one but hey, Its only a friendly claim.
    This is a really good work.
    Thanks!
  • »08.07.26 - 05:38
    kaffeine2
    I’m very happy to know that you are using the OS3 and MorphOS versions almost daily.
    I completely understand the request for a proper MUI GUI, especially on MorphOS. I deliberately did not base this first GUI on MUI, ReAction or Zune because I wanted to keep the same codebase and the same behaviour across the whole Amiga-like family: AmigaOS 3.x, AmigaOS 4.x, MorphOS and AROS.
    So the current GUI is drawn directly using common Amiga/Intuition-style primitives, while sharing the same MTProto core with the TUI. It is not because I dislike MUI. On MorphOS, a MUI frontend would certainly feel more native. The main reason is portability, fewer mandatory dependencies and keeping the project coherent while the core client is still evolving.
    Once the MTProto core and the basic workflow are more mature, separate native frontends can be considered without fragmenting the project too early.
    Thanks again for testing it and for the feedback!
  • »08.07.26 - 05:45
    tolkien
    Good this last version with File sending/receiving and "cloud" storage.
  • »15.07.26 - 10:45
    guruman
    Posts: 462 from 2003/7/21
    First of all, keep up the good work. I do not have a Telegram account, so I have not tested this client yet. And I don't want to derail the thread, so only a quick input for me: if you have an Amiga (or Amiga-like) connected to the net - and if you want to use this client you should - chances your system is not running MUI are close to 0. MUI is used by a lot of Internet-related software. Even if your machine still were a genuine 68k, you would still have MUI to chat on IRC (AmIRC) or read your e-mail (YAM or SimpleMail), which are among the lightest operations you can do. Most browsers are MUI based, FTP clients, RSS clients, and the list goes on... Zune is the MUI source code compatible implementation in AROS, BTW. It's your choice, of course, but chosing the right toolkit might ease the development of your GUI, and avoiding MUI for the wrong reasons might make it harder.
    Kind regards,
    Andrea
  • »17.07.26 - 21:35
    Minuous
    Posts: 166 from 2010/2/12
    Well, I for one don't use MUI, so it's false to assume everyone does.
  • »21.07.26 - 19:58
    kaffeine2
    Kind regards,
    Andrea
    Thanks Andrea, this is a fair point. I agree that MUI is widespread among Amiga users, especially on systems used for Internet software. My concern is not that MUI is unavailable, but that making it a mandatory dependency would complicate the common GUI path across AmigaOS 3.x, AmigaOS 4.x, MorphOS and AROS, where versions and available UI stacks differ.
    For now the native Intuition/GadTools frontend lets me keep one portable GUI sharing the same MTProto engine with the TUI, while the protocol and session layers are still evolving. I am not ruling out a separate MUI/Zune frontend later, sharing the same core, once the architecture is stable. Your suggestion is useful, and I will keep it in mind rather than treating MUI as something to avoid categorically.
    Thanks again for the thoughtful feedback.
  • »22.07.26 - 02:52
    ChrisC
    Posts: 37 from 2025/3/1
    I was hoping you would get to MorphOS with this client, really nice work. Runs really well on my 1200. Thanks!
    kaffeine2 wrote:
    Hi all,
    - chat list;
    - read receipts;
    - MorphOS version;
    Power Mac G5 11,2 Dual 2GHz
    ATI X1950 Pro 256MB
    2GB RAM
    500GB Storage
    MorphOS 3.19 (Licenced)
  • »23.07.26 - 06:46
    kaffeine2
    Thank you! I’m really glad to hear that it runs well on your A1200. The client has been developed in parallel for the different architectures from the beginning, so it’s especially nice to hear that the MorphOS version works well for you. Your feedback means a lot.
  • »23.07.26 - 10:16
    kaffeine2
    Telegram Amiga 0.0.7: main new features
    • Copy/Cut/Paste in the GUI, with mouse or Shift+arrow text selection and a new Edit menu.
    • Much more robust file transfers: streaming uploads/downloads, live progress, automatic retry of lost chunks, reconnect handling and cancellation.
    • Large files supported up to 125 MiB on m68k and 250 MiB on other platforms.
    • Double-click replies, live updates for messages edited on another device, and file transfers with Workbench drag-and-drop in the TUI.
    • Improved online search, including accented names, plus TUI_MODE support for packagers.
    Release article: https://androidlab.it/en/telegram-amiga-alpha-007-large-file-transfers-amigaos-morphos-aros/
  • »25.07.26 - 04:34
