CellBasics - a new upcoming native app
    discreetfx
    Posts: 402 from 2003/7/26
    Looks like it’s development is moving along nicely!
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »09.07.26 - 05:27
    Posts: 2217 from 2003/2/24
    jacadcaps wrote:
    @tolkien
    Import XLSX will only show files with .xlsx extension. CSV would only show .csv.
    I also find this confusing an inconsistent, because usually you filter files with the standard file requester features, but now it shows "#?", but still filters files. I think it would be better with the normal way if users would have some different extensions on purpose, which they still would like to open etc..
  • »09.07.26 - 08:06
    Posts: 1354 from 2004/2/8
    I've managed to crash the program by trying to set an outline to a few cells (the crash can be seen in the last seconds of the video):
    https://youtu.be/Qx8QpprfJvg
    BTW, sorry for laggy video, it's been recorded with software sceen rec.
  • »09.07.26 - 18:09
    Posts: 3311 from 2003/3/5
    Thanks for the report, I'll take a look soon.
  • »09.07.26 - 21:27
    CellBasics 0.58 up with some minor bugfixes.
  • »14.07.26 - 18:40
