DCTelnet on 3.19
  • EVX
    Posts: 29 from 2026/1/10
    I have been attempting to fire up DCTelnet (G5 on 3.19). I have tried a manual install of V1.5 and V1.7 and get the same results. The full screen opens fine and looks great but the system is locked up. I noticed the Caps Lock key doesn't light up when pressed. I have tried a few different screen resolutions (640x256 640x480 800x600) but with the same result. I can't exit out of the screen to debug. Any tips would be greatly appreciated!
    -E
  • »15.02.26 - 15:13
    beworld
    Posts: 667 from 2010/2/10
    Maybe better to create an issue here : https://github.com/bruno-frederic/dctelnet
    IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »15.02.26 - 17:19
    Posts: 1367 from 2010/1/6
    Useing V1.7 without any problems - in full screen (1680x1050) as well as on Ambient in windowed mode.
    You should test it on a plain installation (boot from MOS-CD).
    My system: MorphOS 3.19, PowerMAC G5
  • »15.02.26 - 17:37
    tolkien
    Posts: 558 from 2013/5/29
    I use it too from time to time in morphos 3.19 without problems.
  • »15.02.26 - 19:09
  • EVX
    I suppose I need to redirect this to more of a general query about methods to recover/debug a frozen system. I know DCTelnet can be configured to run in a workbench window after a successful start. I thought about stealing a config file from the program running under UAE and tossing it into the drawer but I need to learn a proper solution to debug this situation. With CMD+M failing (all user inputs appear to be dead) in this case, what other ways can I start a defective full screen program and debug the problem? Just looking for any tips you guys might have.
    -E
  • »19.02.26 - 03:24
