AmigaGPT
    Primax
    Posts: 192 from 2021/7/2
    Hi there.
    I tried to run AmigaGPT under MorphOS 3.19:
    https://www.morphos-storage.net/?id=2359859
    I installed the required MUI classes (GUIGFX, NLists, codesets library) but after stating the tool, it complains:
    missing required MUI classes.
    But it doesn't tell me, which ones. How can I find that out?
    Thanks!
  • »27.04.25 - 05:46
    Posts: 2461 from 2003/2/24
    Snoopium is always a good starting point on such issues.
    It did start right up here on my main system with lots of crud installed over the years.
    On the "new" G5 with a basic install it crashed on not finding codesets.library which suggest the port to be somewhat raw.
  • »27.04.25 - 07:17
    Primax
    @Kronos
    Thanks!
    Obviously, there is a bug in the installer of the guigfx archive:
    https://www.morphos-storage.net/?id=1901738
    It installs: nothing. So, you have to manually copy the guigfx.mcc to Classes/MUI.
  • »28.04.25 - 15:07
