Remote Desktop and Windows 11.
    matt3
    Posts: 784 from 2004/2/10
    I just go a new laptop running windows 11 and I want to RDP into it from my MorphOS box.
    I followed the setup for using group policy editor in windows and I keep getting the message: "ERROR: Failed to connect, no TCP connections with 192.168.168.xxx.
    I had this working fine with my old windows 10 laptop.
    I think I had to do something more to make it work, but I can't remember anymore. :)
  • »19.03.25 - 16:26
    matt3
    Solved!
    I had to go to network and workgroups under the remote tab and turn it on.
    Someone should update the instructions... :)
  • »19.03.25 - 18:21
    Posts: 2217 from 2003/2/24
    I also did set up an RDP connection to a Windows 11 machine earlier this year. I degraded protocol settings as told at the MorphOS Library, and then enabled remote desktop options in Windows. My issue was that Windows settings are so scattered that I only tried to enable it from one place, but then I had to do it some other place too before it started to work. I don't remember anymore where those settings are, should have made notes... but anyway, RDesktop still works with the current Windows versions. BTW. which instructions should be updated? :)
  • »20.03.25 - 10:25
    matt3
    https://library.morph.zone/Applications/RDesktop
    Yes it is in 2 places. One specified in the library above and the other in domains and networks and the remote tab...
  • »20.03.25 - 15:50
