BBS Access Terminal
    ChrisC
    Posts: 37 from 2025/3/1
    I have been using CE' PiMiga for some time and he has Term setup for BBS access, this does not seem to work with MorphOS (telser.device), i was gonna try and set this up but i was wondering if anyone uses a better/newer application or a guide for this?
    Power Mac G5 11,2 Dual 2GHz
    ATI X1950 Pro 256MB
    2GB RAM
    500GB Storage
    MorphOS 3.19 (Licenced)
  • »12.03.25 - 13:14
    Posts: 2217 from 2003/2/24
    I've been using DCTelnet (v1.6) on 800x600 screen. Some occasional character issues, but they go away when you try again few times.
  • »12.03.25 - 14:12
    ChrisC
    Ah nice thanks! I connected to one BBS and the terminal shows no colour, i did select a colour terminal when connecting so is there an option i need to change?
    ATI X1950 Pro 256MB
    2GB RAM
    500GB Storage
  • »12.03.25 - 14:48
    ANSI colors should work when you configure the program to run on its own screen (disable Options->Use Workbench, configure Settings->Screen mode). If it's run on WB/Ambient, then it uses some boring system pens. "Works for me" at least on Amiga (hosted) BBSes.
    [ Edited by jPV 12.03.2025 - 18:47 ]
  • »12.03.25 - 15:44
    ChrisC
    I did follow your earlier guidance to use it on an 800x600 screen rather than having it load on the desktop/workbench screen, i just didn't have any colours, i will try other BBS's and see how it goes, thanks for the help!
    ATI X1950 Pro 256MB
    2GB RAM
    500GB Storage
  • »12.03.25 - 17:07
    Posts: 2565 from 2003/2/24
    ChrisC wrote:
    800x600 screen
    8, 15/16 or 24bit?
    Might make a difference.
  • »13.03.25 - 07:21
    ChrisC
    Which is ideal, i was wondering about that?
    ATI X1950 Pro 256MB
    2GB RAM
    500GB Storage
  • »13.03.25 - 07:27
    8 bit it is, with max colors you can set for it. Now that we talk about it, the color issues on the desktop screen might be because you usually have hi/true color screen on it.
  • »13.03.25 - 10:04
    ChrisC
    Ah really, i am using a 1080p screen in 24 bit, what should i use for the ideal BBS session?
    ATI X1950 Pro 256MB
    2GB RAM
    500GB Storage
  • »13.03.25 - 15:38
    You can have the desktop (Ambient) screen in 1080p/24bit no problem, but just select 800x600x8bit in the DCTelnet screen settings (and don't use it on "Workbench").
    Another option is to configure DCTelnet to open on a 1920x1080x8bit screen, but then you have to set the Width and Height manually to 800 and 600 instead of the default values. Then it opens another screen in the same resolution as your desktop screen, but limits drawing area which fixes the program's issue with bigger resolutions.
  • »13.03.25 - 17:04
    ChrisC
    Thanks for all the help!
    ATI X1950 Pro 256MB
    2GB RAM
    500GB Storage
  • »14.03.25 - 12:57
