About CPU Monitor...
    Blaster
    Posts: 15 from 2004/2/13
    Little time ago, i was thinking about an utility called CPUMonitor
    with some special functions, but as i'm not a coder i haven't do it...
    Fortunaly, someone make it and now it become real ! Thanks Tokai :-)
    Now i would say that would be great if some improvements could be
    add to future releases of CPU Monitor and if CPU Monitor
    could be integrated in MOS.
    Some ideas :
    - Display sensor temperature of CPU
    - Alarm warning at 80-90% of max range temperature (popup windows + sound)
    - Halt CPU during xx minutes when this limit temperature is exceed
    to avoid damage
    - Display CPU Infos (yes, already did it in about Ambient menu)
    More ideas ? ;-)
    - Graphics improvements : grid of xx% (like Win), more colors : for example,
    peaks colorization : yellow (80%), orange (90%) and red (95%)
    - Log CPU activity (sure useless)
    Finally, thanks again to Tokai for your great job. :-)
    Best regards,
    Blaster
  • »28.04.04 - 23:24
    tokai
    Posts: 1289 from 2003/2/25
    hi blaster,
    and if CPU Monitor could be integrated in MOS.
    this does not depend on me. :-)
    this is not supported yet with MorphOS (there is a function but it returns always false) As soon it's supported it will be added (also to statline), but i don't want to hack manually inside some registers.
    maybe. I'll think about.
    some grid is planed. but it will for sure _not_ look like the Display in the Windows taskmanager.
    more colours are 'in development', but they will not show some peak visualization.
    regards,
    tokai
  • »29.04.04 - 09:00
    Blaster
    Thx for your precision, and as we said, keep up the good work ! :-)
    Blaster
  • »29.04.04 - 22:04
