SMB Share shows Dir as File
    Cego
    Posts: 738 from 2006/5/27
    I tried to mount the USB Storage connected to my Router on MorphOS, but all i get after entering username and password is a file.
    Whats the issue here? Mounting the shares on my A1200 works without any problems.
    v3qqK6x
    [ Edited by Cego 03.04.2024 - 12:14 ]
  • »03.04.24 - 09:13
    Posts: 2220 from 2003/2/24
    In that screenshot you have opened a view to all shares at the server (in your case you just have one share to choose from), then you'll have to double-click the share (file) to actually mount it.
  • »03.04.24 - 13:03
    Cego
    That doenst work unfortunately. This is what i get when doubleclicked:
    PhXrBHp
  • »03.04.24 - 14:26
    Posts: 1390 from 2010/1/6
    SMB1 is not supported! Only SMB2/3 - this devices (eg Fritzbox, etc.) will work.
    [ Editiert durch Amigaharry2 03.04.2024 - 18:48 ]
  • »03.04.24 - 14:47
    Cego
    I am using SMBv2. SMB1 is deactivated. When I open up the icon information it says "PNG-Piktogramm"
    [ Edited by Cego 03.04.2024 - 18:12 ]
  • »03.04.24 - 15:02
    There should be a thread about that (MOS 3.18) with Jacad here. Can't find at moment......
  • »03.04.24 - 15:18
    SkulleateR
    Posts: 77 from 2023/9/19
    Works fine here with my FritzBox and MOS 3.18 ...
    Maybe you can try to set up a new User in the router settings for testing ?
  • »03.04.24 - 15:50
    PhXrBHp
    Hmm.. is there Share.info file at all?
  • »03.04.24 - 16:02
    I've the same problem with Win10/7/XP PC. I therefore use smbfs (SMBMounter).
  • »03.04.24 - 16:50
    Cego
    Yes there is an info file
    wZkKX2c
  • »03.04.24 - 16:54
    Cego
    I have recently installed OrangeFTP and some sbar modules. I don't think that any of them would mess up with the SMB client. It worked before, but I can't tell since when this error occurred. Just found out today
  • »03.04.24 - 17:04
    Cego
    After booting from MorphOS 3.18 Install CD, networks: device won't show any files
  • »03.04.24 - 17:14
    Cego
    I reinstalled core MorphOS files with the Update installer of MorphOS3.18 and now it works again. Seems something got trashed inside MOSSYS:
    [ Edited by Cego 03.04.2024 - 20:27 ]
  • »03.04.24 - 17:27
    wZkKX2c
    That "Leer" probably means "empty", so the icon file was broken, it should have some size. Maybe your default icon was broken for some reason...
    [ Edited by jPV 03.04.2024 - 22:33 ]
  • »03.04.24 - 17:31
    Cego
    I have a new issue: When I want to mount the SMB share of my Mac, I get an empty drawer. Mounting a share from my Router (FritzBox) works without any issues.
    When I do a right click and select "Connect..." ("Verbinden...") then "Connect to Server" and enter the IP Adress of my Mac + user name and password I'll get the following output:
    "Failed connecting to 45.76.45.104" (that is not my IP address. its from from France according to IP lookup)
    If I fill out the data at "Mount a Share" I will get a "Failed to connecting to 192.168.192.26". Strange thing is, my network IP range is 192.168.178.###
    What's going on here?
    EDIT: I am now reinstalling MorphOS completely, When the installer asks for time prefs I press on the button to get the time from internet and it'll update the time and date to 09.04.2024 20:11 (but the actual time and date at this point is 11.04.2024 22:44)
    [ Edited by Cego 11.04.2024 - 21:47 ]
  • »11.04.24 - 18:29
    Cego
    did i get hacked? any ideas?
  • »14.04.24 - 16:35
    Is there anything network/mounting/ip address related in the MorphOS debug log? What happens if you try to mount the share with the SMB2FS command in the shell, would it reveal more what's going on?
  • »15.04.24 - 05:32
    Posts: 3337 from 2003/3/5
    I think it's trying to resolve the IP and gets a new IP as a result :) Comes down to your unusual IP range I suppose. I'll see if I can get this fixed. Or you could switch to 192.168.1.* or so and it'll go away...
  • »15.04.24 - 16:14
    Cego
    @jPV @jacadcaps
    i have reinstalled MorphOS and its working again. If there is another way to reproduce the problem i will try
  • »16.04.24 - 16:35
