                Posts: 1289 from 2003/2/25
				http://pegasos.innoidea.hu/stuffz/GG/apache-1.3.27.tgz
1. extract the archive (e.g. with untgz from beta2 ftp)
2. install it like explained in the readme (copy apache directory to gg: and add entries to miami database)
3. load httpd.config from the apache directory and comment the user and group settings:
user www-data
group www-data
#user www-data
#group www-data
then the server runs as root, alternatively you could add the user/group to miami database... :)
4. load up http://127.0.0.1 or http//localhost
then it runs.It's a 1 minute job after all.  :)
later you can edit the settings by changing the httpd.config, if you want.
regards,
tokai
