Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Applications
ZVNC not all keys mapped to PC.
matt3
# 1
Posts: 785 from 2004/2/10
Certain keys (like most on the numeric keypad) do not work on the PC side, they work properly on MorphOS.
Any way to get them working on the PC side?
01.11.23
15:21
MorphOS Developer
Posts: 3337 from 2003/3/5
Not sure about those keys exactly, but the VNC protocol isn't able to map all keys in all situations.
01.11.23
17:13
matt3
# 3
I suspect it just might be some weirdness with 3.19 at this point.
Twinvnc worked perfectly on 3.17 (including numeric keypad, etc.) and now with 3.19 it sometimes won't type or uses hotkey commands when your just typing.
01.11.23
17:22
