VNC viewer for MorphOS
    Posts: 12 from 2022/12/5
    Hello,
    I want to view my raspberry pi from my morphos setup via VNC.
    I have the VNC server setup on the raspberry pi so i need a
    VNC viewer on the Morphos side.
    Is there a viewer for MOS that is native or a 68k version
    that will do the task?
    thanks
  • »17.09.23 - 10:08
    Posts: 2565 from 2003/2/24
    It's been a while, but TwinVNC should work:
    Aminet
  • »17.09.23 - 10:32
    no joy with twinvnc just error disconnected.
    MorphVNC cmd line gives more info:
    MorphOS:Downloads/MorphVNC> MorphVNC 192.168.1.231 raspberry
    Readargs failed
    MorphOS:Downloads/MorphVNC> MorphVNC 192.168.1.231 pass=raspberry
    Connecting to '192.168.1.231' port 5900
    Server supports RFB protocol version 5.0
    Connection failed.
    Server response: No configured security type is supported by 3.3 VNC Viewer
    main.c/main(): RFB_InitializeConnection() failed
    I dont know if that means that MorphVNc is too out of date?
  • »17.09.23 - 11:18
    You might need to reconfigure protocol/security on the server (rPi) side to match the older standards supported.
  • »17.09.23 - 11:39
    Tried form the windows pc and it asks for a user name as well as a password.
    There is no username optioin on the morphos versions i have tried :(
  • »17.09.23 - 11:50
    Posts: 1090 from 2004/9/23
    I suggest using TwinVNC. It works great. I use it 24/7 for more or less everything connecting to LinuxMint.
    In fact I am writing this using TwinVNC.
    I am using
    "TwinVNC v0.8beta [MorphOS/PPC] by Seg (c) Dimension & Dpt22 (09.04.07)"
    so it is quite old, but I remember having issues with newer versions. This one is fine.
  • »17.09.23 - 12:26
    emeck
    Posts: 175 from 2014/7/15
    It used to work for me also but after the last update (or maybe it was the previous the the latest) to RVNC on my Pi it stopped working. I still can connect from my Linux and Windows machines but not from tightVNC anymore.
    PowerBook 5.8 MorphOS 3.18
    Mac Mini MorphOS 3.18
  • »17.09.23 - 12:56
    emeck
    RealVNC server has an option to set "VNC password" which is a specific password to VNC server. That is the one I use. Check your RealVNC configuration.
  • »17.09.23 - 12:59
    I am using
    I am using that version off aminet v0,8b
  • »17.09.23 - 13:59
    Thanks that has worked for 1 older rasspberry pi
  • »17.09.23 - 14:00
    So an update i can connect using twinVNC on the older
    VNC® Server 6.7.2 (r42622) ARMv6 (May 13 2020 19:33:04
    but not on the newer: 6.10.1 r447571 2st july 22
  • »17.09.23 - 14:02
    next question how do i get the older vnc version onto the broken Pi4 which server is too new?
  • »17.09.23 - 14:03
    No clue actually. If the latest linux mint has no issues, the raspi version should work fine, too.
    Ah, I forgot. You should use the x11vnc server and not vino or that is default.
  • »18.09.23 - 11:13
